#1 Posted : 25 November 2016 19:22:30(UTC)
This Smath document is hot from bakery. A must to start getting used.
Inversing a function is also 'solving', from another Smath document.
Thanks Alex for your function x^1/3. It puzzled me a bit why it does
not plot in q(x)-g(x). Finally, eval(,) rescues the plot and enables
RootSecant to work fine, presented here as a "utility".
About numerical solvers for this type of application, everything has
been invented, even the square wheel! that runs flat on cycloidal road.
Why so many ? Because maths are so many, so much.
Enjoy, please post your "difficult solve".
Solve roots_solve RootSecant.sm (39kb) downloaded 51 time(s).
on 26/11/2016(UTC)
Offline Alex M.
#2 Posted : 26 November 2016 00:12:38(UTC)
Alex M.
does not evaluate
thanks 1 user thanked Alex M. for this useful post.
on 26/11/2016(UTC)
#3 Posted : 26 November 2016 01:51:16(UTC)
Originally Posted by: Alex M. Go to Quoted Post
does not evaluate
You have to change the argument Φ into Φ(1) in both the algorithms (RootSecant and Dichotomy)
2016-11-25 23_47_10-SMath Studio - [Solve%20roots_solve%20RootSecant.sm_].png
Not sure why it magically works in 5346, however in this way has the same behavior in both the versions.
Edited by user 26 November 2016 01:55:35(UTC)  | Reason: Not specified
#4 Posted : 26 November 2016 02:08:26(UTC)
5346 is much closer to Mathcad algo by name
which is also closely related to Maple "expression".
#5 Posted : 26 November 2016 02:48:28(UTC)
Found the cause Good
In the original algorithm, functions is not passed by the argument (both in 5346 and the latest), because first argument is not declared to be a function (to figure it, you can replace first argument in RootSecant/Dichotomy definition with a non existing variable, like zzz, you will see the worksheet still works in the same way). The link with the functions in the worksheet is given by this definition, just below RootSecant:
2016-11-26 00_39_01-SMath Studio Desktop - [Solve%20roots_solve%20RootSecant.sm_].png
Here is the cause of the different behaviors:
  • In SS 0.97, f(x) is kept as symbolical definition even if f(x) already exists, hence when you call the algorithms the function Φ(x) to solve in the algorithms is the last f(x) defined before the use.
    2016-11-26 00_41_12-SMath Studio Desktop - [Solve%20roots_solve%20RootSecant.sm_].png
  • In SS 0.98, the definition stores the content of f(x), hence then you ask the algorithms to solve always the same function, bracketed in different locations (wrong bracket -> infinite loop).
    2016-11-26 00_48_02-SMath Studio - [Solve%20roots_solve%20RootSecant.sm_].png
Edited by user 26 November 2016 03:03:56(UTC)  | Reason: Not specified
#6 Posted : 26 November 2016 07:03:15(UTC)
Thanks Davide,
Good doctoring for those users post 5346.
In the attached, added "Newton-Raphson Root Derivative method".
1/1 Mathcad code, works great to augment this useful document.
Cheers, Jean
Solve roots_solve RootSecant.sm (119kb) downloaded 25 time(s).
#7 Posted : 26 November 2016 08:21:40(UTC)
... the cleaned version for your "Numerical solve" classroom.
Solve roots_solve RootSecant.sm (118kb) downloaded 39 time(s).
Offline omorr
#8 Posted : 26 November 2016 11:36:56(UTC)
omorr
Serbia
I think that using functions without brackets as arguments in defining (or calling) another functions wich uses them (like in Mathcad) is generally a bad idea in SMath The reason is relatively simple. You can have variables and functions having different number of arguments but all with the same name in SMath. That is not possible in Mathcad. I suppose different side effects might be present in SMath by copying Mathcad files - like the one Jean presented. In one version of SMath it might work while in the other version the calculation might be performed indefinitely long.
#9 Posted : 02 December 2016 03:53:00(UTC)
Hello Radovan,
Your comment is well posed. However, if it would reveal
that some of the coding attached wouldn't work in recent
Smath build: that is a problem, obliging many work sheets
to be doctored. These three are typical of various algo
constructions.
0Algo Explain.sm (58kb) downloaded 29 time(s).
Genfit Minimize MODEL [Gauss ERRstem].sm (63kb) downloaded 22 time(s).
Image Fourier Zoom Smath.sm (436kb) downloaded 25 time(s).
Offline omorr
#10 Posted : 02 December 2016 10:52:30(UTC)
omorr
Serbia
Hello Jean,
It seems your files are working well (no errors reported). The most important thing is that they are good for you and they could be used (or changed) by the other users.
Best Regards,
