Hello, I have a bunch of long Mathcad files that I would like to insert to a Latex document as an appendix. It is not possible with mathcad as it does not support latex files. Is there by any chance a way to convert mathcad files to latex through SMath studio? Regards MK
What is the point to convert a piece of working maths in dead maths in all sorts of non convertible stuff [Given/Find, symbolic ...] On the other hand, it would be like "reverse Engineer a propriatary software". Do a lot better: select the Mathcad parts, copy, paste in IrfanView, copy from IrfanView, paste in Wingrab, reduce colors 256. Collect/plug in your appendix. All those transits take < 10 sec. Result: absolute quality.
Originally Posted by: MJK Is there by any chance a way to convert mathcad files to latex through SMath studio? If you are able to open the files correctly in SMath, then you can try with Data Exchange] plugin; once it is installed you can save the document as XeLaTeX file (File > Save as...) Originally Posted by: Jean Giraud What is the point to convert a piece of working maths in dead maths If you want/need to create a pdf manual, handbook, etc... is not bad to have text and math as vector objects, that can be rendered/printed at any resolution without loss of quality; even the text parts are much better if they can be selected to be copy/pasted. Edited by user 02 November 2016 14:59:40(UTC)
Originally Posted by: MJK Hello, I have a bunch of long Mathcad files that I would like to insert to a Latex document as an appendix. It is not possible with mathcad as it does not support latex files. Is there by any chance a way to convert mathcad files to latex through SMath studio? Regards MK I've written a program to convert most of the type of math in Mathcad 15 files. Untested for 14 files. May help you? Still in alpa https://github.com/Artif...-Mathcad-to-LaTeX-parser
