Offline Andrey Ivashov
#1 Posted : 01 October 2010 02:11:34(UTC)
Hey! I have really good news today! Clap Biggrinancing:
Hint 1: Local variable and functions are really local now.
Hint 2: Line as a body of definition (right part of equation) is required.
Hint 3: Last element of line(..) function returns an answer to the left part.
Seems SMath Studio 0.90 will be really powerful tool! Thanks to all for helping me with a project!
Best regards, Andrey Ivashov.
Related topics:
  • Operators behavior?
  • User defined functions
  • and others...
    Edited by user 01 October 2010 02:16:40(UTC)  | Reason: Not specified
  • Wanna join the discussion?! Login to your SMath Studio Forum forum account. New Registrations are disabled.
    #2 Posted : 01 October 2010 02:37:33(UTC)
    SMath Studio Live updated with the latest sources, so anyone can test new features:
    Open in SMath Cloud
    Regards.
    Offline oscampo
    #3 Posted : 01 October 2010 02:51:33(UTC)
    oscampo
    Colombia
    Was thanked: 87 time(s) in 66 post(s)
    Thanks a lot!! It's really a wonderful improvement.
    Offline omorr
    #4 Posted : 01 October 2010 08:54:06(UTC)
    omorr
    Serbia
    Dance Biggrinancing: Dance
    I will test it these days - of course Good
    Many thanks Andrey Good
    Offline omorr
    #5 Posted : 01 October 2010 10:13:05(UTC)
    omorr
    Serbia
    Hello Andrey,
    Test 1 Good
    Open in SMath Cloud
    in the 0.89_6, variable "n" will have the same value and variable "y" will be undefined ("i" will be just i -imaginary unit).
    Am I missing something? I've thought that variables "n", "y" and "i" should not be known here. i.e. being local to the function g(x,f(x)).
    Please explain what does this mean. I might be misleading.
    Edited by user 01 October 2010 10:16:41(UTC)  | Reason: Not specified
    Offline omorr
    #6 Posted : 01 October 2010 10:31:25(UTC)
    omorr
    Serbia
    Hello Andrey
    Test 2 Good
    Open in SMath Cloud
    This is nice Good
    Edited by user 01 October 2010 10:35:22(UTC)  | Reason: Not specified
    #7 Posted : 01 October 2010 13:05:49(UTC)
    Radovan, thank you for testing!
    It is an error that I should fix. Variables defined in the right part of expression will not be visible outside of this expression.
    Regards.
    Offline omorr
    #8 Posted : 01 October 2010 13:47:23(UTC)
    omorr
    Serbia
    Wish you good luck Andrey,
    This is one of the greatest feature needed for SMath IMHO.
    Offline omorr
    #9 Posted : 03 October 2010 17:12:41(UTC)
    omorr
    Serbia
    This is also working now Good
    Assignment inside matrix! Matrix has the value and the variables inside as matrix elements.
    Open in SMath Cloud
    #10 Posted : 04 October 2010 01:02:42(UTC)
    Hello.
    Interesting thing - line(..) function on the right part of equation means now that SMath Studio will not even parse all stuff of the line before left part will be called by someone. And here is a side effect:
    This is not the error, but some interesting way to work with functions. In other words it is like one more option of Optimization. Numeric optimization means, that program will try to evaluate right part of equation numerically, symbolic optimization - evaluate symbolically, no optimization means, that program will substitute all previous definitions to the right part of equation and line(..) function at right means that program will not substitute previous definitions to the right part at all.
    Edited by user 04 October 2010 01:06:53(UTC)  | Reason: Not specified
    Offline omorr
    #11 Posted : 04 October 2010 15:37:13(UTC)
    omorr
    Serbia
    smath wrote:
    ... line(..) function at right means that program will not substitute previous definitions to the right part at all.
    This is also a nice one Good . The solution when you want to see how the function was actually defined - without replacing things.
    BTW., just tried 0.89_8. I am not sure but there might be a minor issue. If you have the file "somefile.sm" and in the same folder save as HTML, there would be "somefile.htm" file and "somefile" folder with pictures. Now, if you try to save the compressed SMath studio file with the name "somefile" as the compressed SMath type "*.smz", it will not be saved unless you explicitly type in the file name box "somefile.smz".
    Offline adiaz
    #12 Posted : 01 October 2012 14:05:48(UTC)
    adiaz
    Rank: Member
    Was thanked: 5 time(s) in 5 post(s)
    I'm not comftable with this. As shown in the picture, when write 'g', 'a' appears as 'a = 2'. Others programs have a warning message for the use of global variables locally. I think that you must to introduce a global command to catch the value of a in g(x).
    Regards.
    adiaz attached the following image(s):
    Offline omorr
    #13 Posted : 01 October 2012 16:15:31(UTC)
    omorr
    Serbia
    Hello Alvaro,
    I could not get the same results as you did.
    See the picture please.
    Offline adiaz
    #14 Posted : 01 October 2012 16:44:55(UTC)
    adiaz
    Rank: Member
    Hi. In my example it is (|a*x)*1, but yours is (|a*x*1)
    Regards.
    Offline omorr
    #15 Posted : 01 October 2012 17:03:28(UTC)
    omorr
    Serbia
    Hello Alvaro,
    You are right. This might be sometimes quite frustrating. Everything looks the same but the result is different. SMath can not deal with braces correctly and satisfactory quite often Sad
    This one is one of the examples of that problem I mentioned few times here on the Forum.
    range(1,6*2)=mat(1,2,3,4,5,6,7,8,9,10,11,12,12,1) range(1,6)*2=mat(2,4,6,8,10,12,6,1)
    Edited by user 01 October 2012 17:05:09(UTC)  | Reason: Not specified
    on 01/10/2012(UTC)
    Offline adiaz
    #16 Posted : 01 October 2012 18:05:07(UTC)
    adiaz
    Rank: Member
    Well, as I see, this the price for obtain clarity in others expression. Mathematica have a lot of this problems with TraditionalNotation, Maple too. But at the end, this give less mistakes that working with parenthesis and text notations.
    Defining a function as f(x) := 1*(| ... ) make all variables in line(...) as globals.
    Regards.
