#1 Posted : 22 August 2016 03:05:22(UTC)
Animation adds live to projects.
Enjoy your vist.
0Anim Brownian.sm (9kb) downloaded 46 time(s).
0Anim Analemma.sm (29kb) downloaded 34 time(s).
0Anim Ellipse.sm (14kb) downloaded 41 time(s).
0Anim Cheval.sm (22kb) downloaded 32 time(s).
0Anim Gozilla.sm (12kb) downloaded 37 time(s).
0Anim XFR.sm (12kb) downloaded 33 time(s).
on 22/08/2016(UTC)
Offline Ber7
#2 Posted : 22 August 2016 04:13:52(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Hi Jean
The program will run faster if the code is a little change
0Anim XFR1.sm (14kb) downloaded 28 time(s).
Edited by user 22 August 2016 04:37:12(UTC)  | Reason: Not specified
thanks 1 user thanked Ber7 for this useful post.
on 22/08/2016(UTC)
#3 Posted : 22 August 2016 06:56:24(UTC)
Thanks Ber7 for the code.
On that one "0Anim CONVOLUTION" ... can't accumulate the path ?
Cheers, Jean
0Anim CONVOLUTION.sm (19kb) downloaded 26 time(s).
Offline Ber7
#4 Posted : 22 August 2016 09:57:54(UTC)
Ber7
Israel
Instead tmin = 0 substitute the tmin=1
0Anim XFR1.sm (14kb) downloaded 27 time(s).
on 22/08/2016(UTC)
#5 Posted : 22 August 2016 14:52:26(UTC)
0Anim CONVOLUTION .sm
has been doctored for the accumulated path.
Plots are difficult to size, work sheet is Autocal OFF
0Anim CONVOLUTION.sm (31kb) downloaded 26 time(s).
Offline Andrey Ivashov
#6 Posted : 22 August 2016 18:35:58(UTC)
Thank you for interesting examples!
I've checked your worksheets and see one place for simple optimization applicable for most of them.
Often you use procedures to draw static set of points for all frames of animation. Procedures (when line is used right after the definition operator) calculated on every call - SMath Studio do not precalculate their values.
So, you can speed up calculation simply by line like this:
This line asks the program to calculate procedure and store its values into the initial procedure variable. So, we have only one calculation of static shape for the whole animation!
I've corrected your examples according to the hint above and tested them in both versions: 0.97.5346 - the one you have used to create files and 0.98.6077 - the latest nightly build. Here are the results:
Final versions of the worksheets:
Edited by user 22 August 2016 19:28:29(UTC)  | Reason: Not specified
thanks 3 users thanked Andrey Ivashov for this useful post.
on 22/08/2016(UTC),  on 22/08/2016(UTC),  on 23/08/2016(UTC)
#7 Posted : 23 August 2016 03:39:48(UTC)
Thanks Andrey: I toke good note and adapted.
