#1 Posted : 10 August 2016 18:04:16(UTC)
Refactored for publishing.
Inst_Viscosity Water.sm (28kb) downloaded 56 time(s).
Offline CBG
#2 Posted : 11 August 2016 05:07:03(UTC)
CBG
Hello Jean.
How do you get β:mat(-3.466,487.393,120.455)?
Carlos
#3 Posted : 11 August 2016 16:21:28(UTC)
Hello Jean.
Carlos
_____________________________
... from the "Genfit" minimize(XY,f,φ,β)
It works as well as the Mathcad "Minerr", though not so robust
as the Minerr Levenberg-Marquardt option.
No matter how much maths you will apply around exp(,) it will
not push the fit up to the critical limit. The critical range
is extracted from Thiele continued fraction. If I don't have
it ready done in Smath, give me some time to reconstruct.
Genfit Viscosity Water.sm (39kb) downloaded 21 time(s).
#4 Posted : 11 August 2016 18:08:06(UTC)
... here is Thiele "Water viscosity critical range".
Thiele does not come out of clicking the fingers.
The selection of support points is visual, automated
from "For loop list select" Smath module. Whereas the
continued fraction passes through the support points,
noisy data sets [sampled data are always noisy] take
lot of patience to make it work.
Cheers, Jean
Thiele Model Construct.sm (45kb) downloaded 30 time(s).
