Offline Chin
#1 Posted : 24 August 2010 02:00:11(UTC)
Chin
Could I ask if there is a way to choose a preferred unit after the program has calculated it?
For eg. the default unit for force is in Newtons ('N). If we wish for this to be displayed as kiloNewton (ie., kN) - how should I do this?
Thanks.
Offline Andrey Ivashov
#2 Posted : 24 August 2010 02:28:23(UTC)
Hello Chin!
From the Units implementation topic:
Best regards, Andrey Ivashov.
Offline matteob8
#3 Posted : 07 September 2010 20:38:59(UTC)
matteob8
"Unit" it's a great feature: they are everywhere in my job Good
But I've a little issue: how can SMath understand when I want to express a Moment instead of an Energy?
e.i. I need N*m instead Joule J.
Thanks again for this cool software! Good
Offline omorr
#4 Posted : 07 September 2010 22:01:09(UTC)
omorr
Serbia
I did not quite understand, sorry. Do you actually want insted of J every result to give you N*m ?. What's wrong with the explanation Andrey gave in the previous post - with the picture included - how to change the unit of the result?. Just change J into N*m.
You might even define a new, say, Nm unit like
'Nm:='N*'m or 'Nm:='J
and every J unit replace with Nm unit.
Edited by user 07 September 2010 22:09:38(UTC)  | Reason: Not specified
Offline matteob8
#5 Posted : 07 September 2010 23:09:22(UTC)
matteob8
Thanks Radovan for the prompt reply!
I know: it's a subtle question.
J and N*m seem equals but they are quite different: the first referes to energy, the second to an applied load.
Maybe the following link could clarify the concept: http://en.wikipedia.org/wiki/Newton_metre
In the above link they suggest to use J/rad as an alternate unit for torque but it seems that doesen't work on SMath. Sad
How can I solve this issue?
Thanks for the patience.
Matteo.
Offline maweilian
#6 Posted : 07 September 2010 23:40:39(UTC)
maweilian
Was thanked: 5 time(s) in 5 post(s)
A picture is worth a thousand words:
click on the placeholder on the right and press the apostrophe " ' " to insert a unit:
type in "N * m" (use the dynamic help to make sure you are using the predefined units):
that should give you the units you desire:
Edited by user 07 September 2010 23:42:46(UTC)  | Reason: Not specified
Will Massie
Mechanical Engineer
Oregon, USA
thanks 1 user thanked maweilian for this useful post.
on 09/09/2010(UTC)
Offline matteob8
#7 Posted : 08 September 2010 01:07:50(UTC)
matteob8
Yes! It's what I was looking for!
Thank you Will!
Sorry if bothered you guys, I'd never thought that the solution would be so simple.
Br,
Matteo.
Offline JuanMa_arg
#8 Posted : 29 September 2019 01:17:24(UTC)
JuanMa_arg
Rank: Member
Argentina
Hello, I would like to consult you
                                                I define a temperature in degrees Centigrade, when I call it it looks like Kelvin degrees and then I can't make a sum because it tells me they are two different units. How can I do so that the defined temperature is maintained in every calculation in the unit that defined it?
Attached image capture of the problem.
Thank you
Offline omorr
#9 Posted : 29 September 2019 10:22:37(UTC)
omorr
Serbia
There are many posts on the Forum about handling tempereture units. See for example this one.
on 29/09/2019(UTC)
#10 Posted : 29 September 2019 13:46:27(UTC)
Smath Unit System is ISO, °C is not ISO.
Define your user unit.
If user unit is not '1', don't multiply input by user.
on 29/09/2019(UTC)
#11 Posted : 29 September 2019 15:37:54(UTC)
Visit Colebrook, suggestive how to carry Engineering projects.
And recover units in the results. Each project is specific.
Please, feel free to attach your project for more doctoring.
Inst_Colebrook Pipe Data.sm (62kb) downloaded 10 time(s).
Offline JuanMa_arg
#12 Posted : 29 September 2019 17:30:41(UTC)
JuanMa_arg
Rank: Member
Argentina
thanks to everyone!
#13 Posted : 29 September 2019 23:11:19(UTC)
Originally Posted by: JuanMa_arg Go to Quoted Post
thanks to everyone!
... too much stuff is missing
#14 Posted : 30 September 2019 01:03:50(UTC)
ry practice ignoring unit system.
Only OK for baby stuff: 2*2=4m²
#15 Posted : 30 September 2019 04:06:13(UTC)
The difference operator is often useful.
Guest (2)
