Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Hi, Attached is a Smath file showing how a first estimate is made of the hydro power potential from stream flow data. This is based on the "Example 6.11 - E.M. Wilson - Engineering Hydrology - Fourth Edition - Solutions to Problems" published as a solution manual to the text book by the same author. |
2 users thanked ndtma for this useful post.
on 20/10/2015(UTC), on 08/04/2016(UTC)
integrals aren't calculated in this example. Culprit is maxima plugin. Edited by user 08 April 2016 14:22:30(UTC)
| Reason: Not specified
