2 Pages<12
#21 Posted : 02 March 2016 18:12:26(UTC)
Was thanked: 1330 time(s) in 876 post(s)
new beta release 0.98.5905 available, should fix problems even for those who didn't update plug-ins
All links are already updated (see #1)
(on behalf of Andrey)
Edited by user 02 March 2016 18:23:57(UTC)  | Reason: Not specified
on 02/03/2016(UTC),  on 02/03/2016(UTC)
Offline uni
#22 Posted : 02 March 2016 19:38:20(UTC)
uni
Maple Wrapper plugin can help with some symbolic problems.
Russia ☭ forever
Viacheslav N. Mezentsev
#23 Posted : 02 March 2016 20:57:39(UTC)
Hello Uni,
Which one is right, which is wrong ?
Personally: I would scrap Smath from subscripted variable.
Offline uni
#24 Posted : 02 March 2016 21:08:07(UTC)
uni
All answers are correct. I just have invisible braces. If you click on the expression, then they appear. I don't know why it happened.
Russia ☭ forever
#25 Posted : 03 March 2016 04:43:40(UTC)
I trust you Uni, because I know you tell the truth.
But an an algebraic result to be copied as such, wrong.
Maple does not like subsrcipt. That by clicking it shows
the brackets, to me it is a bug that it does not
output the right result.
I accept the subscript as a local tutorial demo.
For real work and particularly for publishing: NO subscript.
Cheers, Jean
#26 Posted : 03 March 2016 05:16:00(UTC)
Originally Posted by: Alex.M Go to Quoted Post
I have a 30 page SMath file that does not run on 0.98; The error points down to the summation function
I the worst instance, I noticed Sum limited to N = 11
My Ksmoothlet takes over 100. I didn't pursue
the hypergeometric as it turned red at very low N.
Too low N for that is useless as it flies in the blue.
In the fft/icfft [about two months ago], the length of
accepted N is not constant. Puzzling, live with it.
Attach the part of the work sheet that points the Sum error.
Offline uni
#27 Posted : 03 March 2016 07:22:33(UTC)
uni
Don't worry about subscripts. For the variables subscripts supported as was described here.
If Maple Wrapper meet a variable with the dot (comma) in its name this name will wrapped with the symbol `. You can see this in log file (<plugin folder>\mvr5\mvr5.txt).
The log for int(x.1,x.1):
Code:
03.03.2016 9:20:29 [->] smath_int(`x.1`,`x.1`)
03.03.2016 9:20:29 [->] C:\Temp\tmpAC26.tmp:
interface(quiet=true);
with(linalg):with(inttrans):with(plots):
writeto("C:\\Temp\\tmpAC27.tmp"):
smath_line := proc() local i: for i from 1 to nargs - 2 do args[i]; od: end:
smath_sum := proc() if nargs = 1 then sum( args[1] ); elif nargs = 2 then sum( args[1], args[2] ); elif nargs = 4 then sum( args[1], args[2] = args[3] .. args[4] ); fi: end:
smath_product:= proc() if nargs = 1 then product( args[1] ); elif nargs = 2 then product( args[1], args[2] ); elif nargs = 4 then product( args[1], args[2] = args[3] .. args[4] ); fi: end:
smath_int := proc() if nargs = 2 then int( args[1], args[2] ); elif nargs = 4 then int( args[1], args[2] = args[3] .. args[4] ); fi: end:
smath_diff := proc() if nargs = 2 then diff( args[1], args[2] ); elif nargs = 3 then diff( args[1], args[2] $ args[3] ); fi: end:
smath_sys := proc() { args[i] $ i = 1 .. nargs - 2 }; end:
smath_el := proc() args[1][ args[2] ]; end:
smath_mat := proc()
local i, j, out:
out := [ args[j] $ j = 1 .. args[ nargs ] ]:
for i from 2 to args[ nargs - 1 ] do
out := out, [ args[j] $ j = ( i - 1 ) * args[ nargs ] + 1 .. ( i - 1 ) * args[ nargs ] + args[ nargs ] ]:
od:
 convert( [ out ], array );
end:
smath_submatrix := proc() submatrix( args[1], args[2] .. args[3], args[4] .. args[5] ); end:
ans := \
smath_int(`x.1`,`x.1`):
if ( whattype( ans ) = `exprseq` ) then
    convert( convert( cat( `mat(`, substring( convert( [ans], string ), 2..-2 ), `,`, nops( [ans] ), `,1)` ), string ), symbol );
elif ( whattype( ans ) = `set` ) then
    convert( convert( cat(`mat(`,substring(convert(map2(op,2,[ans[i]$i=1..nops(ans)]),string),2..-2),`,`,nops(ans),`,1)`), string ), symbol );
elif ( whattype( ans ) = `symbol` ) then
    convert( convert( eval( ans ), string ), symbol );
elif ( whattype( ans ) = `series` ) then
    convert( convert( ans, polynom) , symbol );
elif ( whattype( ans ) = `string` ) then
    convert( ans, symbol );
else
    convert( convert( ans, string ), symbol ); fi;
quit:
03.03.2016 9:20:29 [<-] C:\Temp\tmpAC27.tmp:
1/2*`x.1`^2
03.03.2016 9:20:29 [<-] 1/2*x.1^2
Russia ☭ forever
on 03/03/2016(UTC)
#28 Posted : 03 March 2016 07:48:09(UTC)
Uni,
I most appreciate you know Maple and prove/demonstrate
it takes subscript. Why the 1rst display was wrong ?
Not disaster as we have to copy/paste result, doing
like you mentionned earlier click to see the bracket.
Can you make the attached "Fourier Quantum" work ?
Fourier Quantum.sm (26kb) downloaded 40 time(s).
Offline uni
#29 Posted : 03 March 2016 11:49:33(UTC)
uni
Why the 1rst display was wrong?
I don't know. May be Andrey will see this and make some comments.
Russia ☭ forever
on 03/03/2016(UTC)
Offline Andrey Ivashov
#30 Posted : 12 March 2016 02:32:51(UTC)
Hello.
Thank you for figuring it out!
Issue was in Math Region. It is fixed now. Fix will be available in new SMath Studio build.
on 12/03/2016(UTC),  on 12/03/2016(UTC)
Guest (2)
2 Pages<12
