SMath Studio Forum
Questions
Opening a .xmcd file in SMath Studio
Morning, I get an error message wehen opening a Mathcad .xmcd file in SMath Studio. I have Mathcad V14 and SMath Studio V0.97 (built:5346). I have attached an image of the error message. Some of the file is converted propoerly but i have an issue with the IF functions. I have attached the mathcad file which i need converted as well. Thanks Steve File Attachment(s): SteveG021 attached the following image(s):
Joined: 03/02/2014(UTC) Posts: 67 Was thanked: 13 time(s) in 11 post(s)
Wasn't this addressed in your last post (http://en.smath.info/forum/yaf_postst4702_If-statements.aspx#post23827) ??
The problem was in your "max" function in section 1.8. "max" function needs to have the arguments inside a matrix, to have it in the format you have (arguments separated by a comma) you have to use the "Max" function. Capital and lowercase makes a difference.
You have several "min" functions with the same issue (Section 1.5 and 1.6), where it needs to be changed to "Min".
SMath Studio Forum
Questions
