Hi, I installed SMath Studio 0.87 today and first everything worked fine, but then I got an error when selecting the menu "Help / Examples". The error I get is shown in the screenshot. Right after installation, this worked fine and I could open various examples. But now, opening examples via the Help/Examples menu does not work anymore. Everything else still seems to work fine. I can open examples via "File / Open" and make calculations without problems. I can also open new calculation pages, etc. The only problem seems to be opening examples via Help/Examples. I uninstalled, then re-installed SMath, but the problem remains the same. I am using Windows XP Pro SP3. I installed SMath Studio using SMathStudioDesktop.0_87.Setup.msi Any ideas? See screenshot of the error and the error message. Kind regards Eddy Quote:See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text ************** System.IndexOutOfRangeException: Index was outside the bounds of the array. at SMath.Desktop.Examples.Examples_Load(Object sender, EventArgs e) at System.Windows.Forms.Form.OnLoad(EventArgs e) at System.Windows.Forms.Form.OnCreateControl() at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible) at System.Windows.Forms.Control.CreateControl() at System.Windows.Forms.Control.WmShowWindow(Message& m) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ScrollableControl.WndProc(Message& m) at System.Windows.Forms.ContainerControl.WndProc(Message& m) at System.Windows.Forms.Form.WmShowWindow(Message& m) at System.Windows.Forms.Form.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies ************** mscorlib Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SMathStudio_Desktop Assembly Version: 0.87.3692.42684 Win32 Version: 1.1.13.0 CodeBase: file:///D:/Program%20Files/SMath/SMath%20Studio/SMathStudio_Desktop.exe
System.Windows.Forms Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ioman Assembly Version: 0.87.3692.42680 Win32 Version: 0.87.3692.42680 CodeBase: file:///D:/Program%20Files/SMath/SMath%20Studio/ioman.DLL
SpecialFunctions Assembly Version: 1.0.3692.42563 Win32 Version: 1.0.3692.42563 CodeBase: file:///D:/Program%20Files/SMath/SMath%20Studio/plugins/SpecialFunctions.dll
canvas Assembly Version: 0.87.3692.42682 Win32 Version: 0.87.3692.42682 CodeBase: file:///D:/Program%20Files/SMath/SMath%20Studio/canvas.DLL
System.Configuration Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml Assembly Version: 2.0.0.0 Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000) CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
SyLib Assembly Version: 1.20.3692.42681 Win32 Version: 1.20.3692.42681 CodeBase: file:///D:/Program%20Files/SMath/SMath%20Studio/SyLib.DLL
NuLib Assembly Version: 1.53.3692.42681 Win32 Version: 1.53.3692.42681 CodeBase: file:///D:/Program%20Files/SMath/SMath%20Studio/NuLib.DLL
************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled.
For example:
<configuration> <system.windows.forms jitDebugging="true" /> </configuration>
When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.
Many thanks for the report. I've made some improvements for you in the main programs executable file: SMathStudio_Desktop.exe. Please, could you download it: http://smath.info/?file=739013 (zipped file), unpack and replace original SMathStudio_Desktop.exe with this debug version? Hope you will not see any messages, but if the problem will appear again SMath Studio will not go down - you'll just see a message with some information. If so, please, send me screenshot of this message. Thank you. Best regards, Andrey Ivashov.
I replaced the executable and everything works fine now! Thanks for your quick action!
Kind regards Eddy
