RC: SMath Studio 0.97.5327 available - Simplification error fixed (incorrect sign of the operand appeared sometimes for complex expressions);
- SS-173: Wrong display of units with subtext if comma is set as decimal separator;
- SS-2: Fixed issues with lost regions under bottom Area part after save to SM/SMZ file;
- SS-171: Collapsed Area related issues are fixed;
- Delete and move operations improved for Collapsed Areas;
- Crashing on application start fixed in case of incorrect response from server on check for update operation;
- Incorrect description of several units fixed (like 'kg);
- Refactoring.
Download
8 users thanked Andrey Ivashov for this useful post.
on 02/08/2014(UTC), on 02/08/2014(UTC), on 02/08/2014(UTC), on 02/08/2014(UTC), on 02/08/2014(UTC), on 02/08/2014(UTC), on 02/08/2014(UTC), on 02/08/2014(UTC)
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1127 time(s) in 723 post(s)
Some observation on area regions: - Opening and closing separators of an area region do not know anything about each other, just as with opening and closing parens.
- Therefore, now you cannot create overlapping area regions any more, instead you create nested area regions. This logic is straightforward and might solve the original request.
- Opening and closing separators are matched by nesting level and proximity. Deleting any area separator now also deletes the matching one, which was ioan's request 1
- Color changes to any separator of an expanded area just affect this separator. The matching separator and the contents inside are not affected.
- Color changes to a collapsed area region affect everyting (separators and contents.
- Only remaining issue of SS-98 is saving the contents of an area region to a file. Current workaround would be to copy the region (possibly collapsed) to a new file.
Thanks for the fix of the abs/root bug. Obviously this was not related to SS-26, as the problem of unit simplification seems to persist |
Hello Andrey, Thank you for fixing things up . By the way, I've noticed the different behavior of power operator. Sometimes it adds extra brackets (cos(x))^#end we can not get rid of them. I might not pay enough attention about this, but just curious what is the reason of this change? Regards, Radovan omorr attached the following image(s): |
Originally Posted by: ioan92 I noticed that in this version, every time when a new line is introduced, the recalculation (starting with the areas following the introduced new line ?) of the file is operated, even if the automatic recalculation option is not activated. Please check.
Filed as SS-190 |
I will worship you 3 times a day if you add a font toolbar XD
As always, thanks for the updates!
Originally Posted by: blarg I will worship you 3 times a day if you add a font toolbar XD
As always, thanks for the updates! For the time being the Text region utility plugin by Davide Carpi might help. There is a page in the interactive handbook (can't attach it here). You access it via [?]> Plugins> Text region utilities It is pre-installed in the portable distribution |
