Offline RFreund
#1 Posted : 09 October 2013 21:17:29(UTC)
RFreund
Was thanked: 19 time(s) in 17 post(s)
Is anyone able to open the attached document in SMath?
I receive an error regarding a text region. Is there anyway to open this?
Thanks,
Ryan
File Attachment(s):
Tor_Fi.xmcd (198kb) downloaded 145 time(s).
#2 Posted : 15 October 2013 11:58:18(UTC)
If you use the "file" > "open..." option you should open the file. A dialog show you the errors importing the file, then all other things will be imported (see the attachment)
If in your xmcd worksheet there are things that are present in SMath Studio but are not properly imported post a message in the bugs & problems section of the forum, the author will improve the plugin Good
regards,
Davide
File Attachment(s):
Tor_Fi.sm (44kb) downloaded 30 time(s).
Offline shrines
#3 Posted : 01 November 2013 23:48:14(UTC)
shrines
I am having a similar problem to RFreund. I converted all of my Mathcad 2000 .mcd files to Mathcad 15 .xmcd files. In that process I verified all converted files open and compute correctly in Mathcad 15. I then tried to open my newly converted files in SMath version 0.96 (build 4868). I tried about 20 different .xmcd files and every one gave me the same error message and did not open.
For every attempt to open a .xmcd file I was presented with an SMath Studio dialog box that states:
C:\path\filename.xmcd
Could not load file or assembly 'TextRegion, Version=1.9.4868.42191,
Culture=neutral, PublicKeyToken=null' or one of its dependencies.
The system cannot find the file specified.
My interpretation of the last line is that there is perhaps a file (DLL?) missing that is required for the conversion.
The About dialog box for my SMath installation lists SyLib, NuLib, canvas and ioman DLLs.
I can send an example .xmcd file if would be helpful in identifying the problem. Let me know.
--Steve
File Attachment(s):
Air Displacement.xmcd (67kb) downloaded 90 time(s).
Offline mkraska
#4 Posted : 02 November 2013 00:23:21(UTC)
mkraska
You might try a more up to date distribution (e.g. the unofficial one, see my signature). At least, SMath Studio 0.96.4909 can read the file attached by you without problems. See attached .sm file generated from your file.
File Attachment(s):
Air Displacement.sm (19kb) downloaded 111 time(s).
Offline shrines
#5 Posted : 04 November 2013 19:24:54(UTC)
shrines
That did it! Now that the files load I can use the error messages to figure out which plug-ins I need to get the rest of the files working (mostly Maple, I think). Thanks!
Mit freundlichen Gruessen,
--Steve
Similar Topics
Problems with opening mathcad files (Questions)
by soletto 05/07/2016 21:33:55(UTC)
