Offline Macclad
#1 Posted : 23 October 2013 00:14:50(UTC)
Macclad
United Kingdom
Hi all
Hopefully this is a simple question that I guess someone can answer. I am programming the stiffness method for a 2D sway frame example, and with the degrees of freedom I have active, I have produced a mixed unit stiffness matrix. I have previously attempted this in mathcad but had to strip the units out for it to allow me to produce the stiffness matrix at all. So I can see that Smath will allow mixed units in the matrix (which is a step forward from my verion of mathcad), but when I try using K to the power -1 to invert the matrix it flags an error.
So is it because a) Im using a slightly out of date version, Cool It can't do it because of the units in the matrix, c) is there an alternative way of doing this without stripping out the units? Im not particularly keen to program a solver like Gauss elimination etc as that would defeat the object of trying to get the program to do this automatically for me.
Any advice would be greatly appreciated.
Many thanks
Laurence
Offline mkraska
#2 Posted : 23 October 2013 00:45:41(UTC)
mkraska
You might use the Maxima plugin. It is in early alpha state, thus be careful.
Offline Macclad
#3 Posted : 23 October 2013 10:08:48(UTC)
Macclad
United Kingdom
Many thanks Martin - I will try this out and report back as to how I get on.
Laurence
Offline omorr
#4 Posted : 23 October 2013 11:09:59(UTC)
omorr
Serbia
I did not get this, sorry.
Just tried the example from Martin and got the same answer without using Maxima.
Did not understand what was the problem here and when will SMath fail actually.
Offline Macclad
#5 Posted : 23 October 2013 14:04:26(UTC)
Macclad
United Kingdom
Hi, many thanks for this
Hopeully I have attached a screenshot ok. I am solving a 7 degree of freedom
system with all but one of the degrees of freedom being rotational (DOF 4 is
translational). So when I ask for the inverse it comes back with the statement
'units dont match'.
Having looked at it further, could it possibly be that I have a number of
zero's in the matrix with no units attached at all? I would have thought not
as this still contitutes a mixed unit matrix, however my maths in the area of
matrix inversion needs a little bringing up to speed!! Also I believe I have the units correct
Hopefully the screenshot will explain what is going on
Laurence
File Attachment(s):
Offline Macclad
#6 Posted : 23 October 2013 14:35:28(UTC)
Macclad
United Kingdom
Please see attached screenshot - I cannot get the example you are using to work. So Im guessing this could possibly a version issue? I will check for updates now, im sure I have build 0.96 desktop. I will keep you posted.
Laurence
Edited by user 23 October 2013 14:56:10(UTC)  | Reason: Not specified
File Attachment(s):
Offline omorr
#7 Posted : 23 October 2013 15:43:05(UTC)
omorr
Serbia
Hello Laurence
I am sorry if I produced a confusion here. I used symbolical evaluation, not numerical. Unfortunately, we can see thee same character on the screen. It seems that was not a good idea to change the appearance of both symbolical and numerical evaluation into the same character on the screen. Martin also mentioned this few times as well. See the attached screenshot. I've noted the difference now.
To correct myself. SMath will fail on the numerical evaluation here. Maxima will do this quite well.
Edited by user 23 October 2013 15:45:04(UTC)  | Reason: Not specified
Offline Macclad
#8 Posted : 23 October 2013 20:45:02(UTC)
Macclad
United Kingdom
Hi Radovan
Many thanks, I have just used symbolic optimisation and that appears to have sorted this problem out - the displacements now appear to be as per my checking exampleBiggrin . I have come across the numerical/symbolical problem before but I had dismissed this (I previously posted a long time ago regarding an example where symbolical calculation gives incorrect answers for displacement, correct ones when using the numerical evaluation?Confusion ). The symbolic approach tends to take a little while to calculate on my computer but that's just a hardware issue - I might try the maxima plugin also.
Once again, many thanks for your expert advice on this thread.
Laurence
Offline RFreund
#9 Posted : 24 October 2013 01:22:25(UTC)
RFreund
Was thanked: 19 time(s) in 17 post(s)
I have a related question so I will post here unless you feel it needs it's own thread:
Is there a way to show the results of a matrix in the individual 'cells' as different units? I like to display matrices as you would a table however it becomes confusing if I try to show a row of force then a row of length then say a row with no units.
Thanks,
Ryan
Offline mkraska
#10 Posted : 24 October 2013 03:01:55(UTC)
mkraska
As I understand, this is on the agenda for the development of the TableRegion plugin
You also can use a diagonal matrix with units specifying the results units of each column. However, for me, that does not look really smart.
The multiplicative result split works for matrices as well, in fact, this is another way to write a matrix inversion.
#11 Posted : 24 October 2013 09:33:40(UTC)
That's the idea, not cell-by-cell but by rows or by columns, even if actually I Don't know how Biggrin
Offline mkraska
#12 Posted : 24 October 2013 14:20:44(UTC)
mkraska
Can't you choose a vector from the sheet (just like in plots for t values or in combobox region)? The rest looks easy (I may oversee important issues).
#13 Posted : 24 October 2013 15:00:18(UTC)
As principle yes, my problem is how to display the right unit in the header without "patches"... f.e. one might want to display kPa or kN/m^2 or kJ/m^3...
Edited by user 24 October 2013 16:50:34(UTC)  | Reason: Not specified
Offline mkraska
#14 Posted : 24 October 2013 16:57:31(UTC)
mkraska
What does mean "without patches"? The right unit is in the given header vector. Eventually, make it string before handling over to the table.
#15 Posted : 24 October 2013 18:15:05(UTC)
homemade patches....
only if it's possible to have the input values without preprocessing.... That's the same issue of the units of a null initial guess...
#16 Posted : 24 October 2013 18:16:12(UTC)
Maybe this is not a problem with custom regions, I don't know (not yet...)
Edited by user 24 October 2013 18:25:38(UTC)  | Reason: w3b5urf3r_reloaded
