Joined: 15/05/2012(UTC) Posts: 14 Location: Profeta Miqueas Oe10-309 y Tabiazo Was thanked: 7 time(s) in 4 post(s)
I don't know if this problem has been already reported, but I see some weird behavior with some simple integrals, this happen when I try different kind of optimizations (symbolic, numeric or none) at the same time I try different kind of fraction convertions(decimal, fracction or auto), when I try the eval function I get the same problem. I attach a file done in the latest stable version (0.96 build: 4868), showing this behavior. Edited by user 26 July 2013 01:26:44(UTC)
Ecuadorian Electronic engineer and MBA student at Salesian Polytechnic University. |
2 users thanked Jarrinator for this useful post.
on 26/07/2013(UTC), on 26/07/2013(UTC)
Confirmed in 096_4909
It seems that wrong result will be when the Fractions: Fraction/Auto and Optimization: Numeric
Regards, Radovan
The problem is solved by the Maxima plugin. However, currently you need to explicitly let Maxima take over the functions, otherwise the integrals will work the old way. [EDIT] Adaption to current state of Maxima plugin Edited by user 23 September 2013 01:08:13(UTC)
| Reason: Not specified mkraska attached the following image(s): |
