Offline thesansman
#1 Posted : 19 September 2013 20:54:12(UTC)
thesansman
Hello all
I have two vectors with scalar and direction that I want to add and get a resulting vector that has scalar and direction. I can't seem to figure this out? Basically I have a force problem that I am solving for and I figured this would be best done by adding the vectors to get the resulting force however I can't seem to figure this out on SMath.
Thank-you to all who answer.
#2 Posted : 20 September 2013 19:11:07(UTC)
Can you post an example (from literature or made by you)?
Offline kilele
#3 Posted : 21 September 2013 00:14:59(UTC)
kilele
oops I never tried this, I think he means this
http://www.1728.org/vectors.htm
I might be wrong but SMath does not calculate sum of vectors given in polar coordinates correctly
on 21/09/2013(UTC)
Offline mkraska
#4 Posted : 21 September 2013 01:03:54(UTC)
mkraska
Actually, there are several ways to calculate vector sums. In 2D the most natural way for vectors given in polar form is using complex numbers. In mechanics, we usually transform to cartesian components, as this can be generalized to 3D.
Unfortunately, this example reveals that the handling of sums in Maxima plugin is very weak at the moment. Therefore, we have to "surrender" for the moment.
File Attachment(s):
Example adding 2D vectors.sm (15kb) downloaded 23 time(s).
#5 Posted : 21 September 2013 01:06:30(UTC)
I think you are right; BTW is a quite simple problem, so one can build his own function, with the most appropriate input standard that he think better and, like has Martin said, there are several ways to process the problem Good
Edited by user 21 September 2013 01:08:55(UTC)  | Reason: Not specified
Offline kilele
#6 Posted : 21 September 2013 13:58:41(UTC)
kilele
I think the question is about adding vectors entered in polar form as in the first expression. Note that SMath does not return the correct result.
Edited by user 21 September 2013 14:00:14(UTC)  | Reason: Not specified
kilele attached the following image(s):
Offline mkraska
#7 Posted : 21 September 2013 15:10:45(UTC)
mkraska
Lists and list operations are not a good representation for vectors and vector operations. If lists obtained by pol2xy are to be added, they must be converted to vectors using sys2mat().
File Attachment(s):
Section lists operations.sm (44kb) downloaded 21 time(s).
Offline kilele
#8 Posted : 21 September 2013 15:38:27(UTC)
kilele
@ioan92
Nice explanation on how to get a result. The point of the original question, I think, was a direct way using only polar notation provided by SMath
@mkraska
I forgot to apply sys2mat to an expression involving more than one system, anyway the result of that sum is incorrect.
on 21/09/2013(UTC)
