3 Pages123>
#1 Posted : 18 September 2013 18:25:57(UTC)
Hi all,
Here there is a plugin to make single or multiple snapshots inside SMath Studio's worksheets without using external tools.
FEATURES:
- sets of snapshots (the set name is taken from the placeholder);
- progressive numbering for each set;
- save by context menu: selected frame / any frame of the set of the selected frame / any frame on the worksheet;
- each frame can keep or skip canvas' tile;
- pasting a text into the placeholder this will become a SMath string variable;
- hidden in SMath Viewer (by design).
Plugin languages: English Deutsch Italiano Español
PLEASE REPORT IN THIS TOPIC ANY ISSUE.
  • requirements: SMath Studio 0.96.5146 Nigthly build or later, .Net Framework 2.0;
  • installation: download the plugin from the gallery;
  • documentation: download and unzip the attached archive;
  • sources: if you want to see the plugin sources look in the SVN repository;
  • languages: if you want to have a new UI language look into the documentation's Language folder
Edited by user 07 February 2014 15:00:35(UTC)  | Reason: requirements updated
File Attachment(s):
SnapshotRegion_docs.7z (27kb) downloaded 136 time(s).
thanks 4 users thanked Davide Carpi for this useful post.
on 18/09/2013(UTC),  on 18/09/2013(UTC),  on 18/09/2013(UTC),  on 19/09/2013(UTC)
Offline omorr
#2 Posted : 18 September 2013 20:53:39(UTC)
omorr
Serbia
Thanks for your efforts Good , but I am not quite sure what this plugin is supposed to do? I can put it on the page, make a set, save it as PNG snapshots.
On the other hand, I can resize it horizontally, but not vertically.
radovan
#3 Posted : 18 September 2013 21:05:19(UTC)
Hi omorr, thank you for your feedback Good
The plugin is intended for batch screenshots (I think could be useful for relations, handbooks, guides, websites...) =)
You don't see resize's placeholders or you really can't resize the region? For the first issue I've planned something without loosing the "dark look", if there are bugs let me know...
best regards,
Davide
Edited by user 18 September 2013 21:10:42(UTC)  | Reason: Not specified
Offline mkraska
#4 Posted : 18 September 2013 21:51:34(UTC)
mkraska
As already said in PM: Sometimes dreams come true.
- I confirm the resizing problem.
- Area regions must be expanded, otherwise the snapshot contents is shifted by the amount of hidden vertical space.
- Would be fine if the choice of saving location could be kept or if the default would be the location of the sm-file.
- Would also be fine to launch the complete snapshot production upon save of the file.
I have asked in the past for such a feature. This provides an automated way for update of images used in any type of documents. You may link them to word or ni latex files. The idea was to automatically update all images of the pdf handbook without touching them, e.g. after new SMath releases or after bugfixes of plugins.
I am using the latex front end LyX for writing handbooks and the like. This program can embed external material, by describing what type of source generates the image, what program does open it and what image format it produces.
Thus you may click a snapshot in your editor, SMath is launched, youn can edit the contents, save and exit, and have the image updated. That can be as convenient as Mathcad used to be in former times.
#5 Posted : 18 September 2013 22:18:20(UTC)
Thank you Martin Good
I don't understand or I can't replicate the issue (see the attchment)
I'll do, it's quite easy
I'll think to this, maybe I'll add a variable to enable/disable this feature, like in some plugin made by uni..
best regards,
Davide
Offline mkraska
#6 Posted : 18 September 2013 22:50:25(UTC)
mkraska
In the example, the snippet region is collapsed, the contents of the exported file is from somewhere below the snapshot region.
File Attachment(s):
example support reactions linear system.sm (35kb) downloaded 58 time(s).
Offline omorr
#7 Posted : 18 September 2013 23:19:08(UTC)
omorr
Serbia
Davide, look at the first picture please - there is only one placeholder at the right side for resizing. I con not find the placeholder on tho bottom or at the right corner.
Martin, look at the second picture please. Where is this comming from Shok . I just opened the file you attached to the previous post and this message box appeared. Is there any Maxima plugin in the development and not available at the moment?
Edited by user 18 September 2013 23:21:31(UTC)  | Reason: Not specified
Offline mkraska
#8 Posted : 19 September 2013 00:16:15(UTC)
mkraska
Sorry for the confusion. LinSolve(2) is from Maxima, I forgot to switch that back to the snippet version LinSolve(1). Just remove the second argument, then the file should run.
The plugin is going to go public soon. One of our students is doing a great job with the coding work, I am doing the specification/docs and the testing. We just want to have the user interface (functions) to settle a bit. You find some doc preview in the SVN activebook. You can use the waiting time to install Maxima (plugin developed and tested under win only).
#9 Posted : 19 September 2013 00:32:18(UTC)
No, there are 3 placeholders, you can't see them because the background is close to black. From my smartphone and from my notebook (with sloping LCD) I can see both the bottom placeholders... don't worry, I'll make something - BTW if you move the pointer over the bottom-left corner or over the half width of the bottom edge the mouse cursor will change.
Thank you, that's my lack Wink
Thank you both Good
Edited by user 19 September 2013 13:59:50(UTC)  | Reason: Not specified
#10 Posted : 19 September 2013 01:33:34(UTC)
UPDATED
- fixed vertical shift when the frame is below collapsed regions;
- change of background behind resize's placeholders (when the region is focused);
- default save folders on dialogs is desktop for new documents, otherwise worksheet's path;
- added Italian and German translations.
Edited by user 19 September 2013 07:52:08(UTC)  | Reason: Not specified
Offline omorr
#11 Posted : 19 September 2013 13:36:34(UTC)
omorr
Serbia
I am very pleased to know this Good and also looking forward to the many times mentioned possibility of Maxima plugin for SMath.
Edited by user 19 September 2013 15:23:46(UTC)  | Reason: Not specified
Offline omorr
#12 Posted : 19 September 2013 15:19:25(UTC)
omorr
Serbia
Davide,
I suppose you figured out how to use Greenshot and to see the resize arrow because you deleted the question in your previous post (You are right, I am using it as well). Just in the Preferences set to see the mouse and increase the the time delay in order to have enough time to change the mouse appereance.
Edited by user 19 September 2013 15:23:03(UTC)  | Reason: Not specified
on 19/09/2013(UTC)
#13 Posted : 19 September 2013 15:39:23(UTC)
Thank you Radovan, that's exactly what I need Dance
My first rude solution was to press "more resolutely Spiteful " the stamp key, I've missed that setting Thank you
Edited by user 19 September 2013 15:51:04(UTC)  | Reason: Not specified
#14 Posted : 20 September 2013 01:21:00(UTC)
UPDATED
- changed top and bottom ribbon height (better look on tag wrap and region resize);
- small fixes.
#15 Posted : 20 September 2013 15:50:29(UTC)
UPDATED
- can export the canvas tile (off by default).
* if you need to update sheets where there are Snaphot Regions, add inside the worksheet code the attribute
Code:
tile="False"
Offline mkraska
#16 Posted : 22 September 2013 22:24:44(UTC)
mkraska
Currently, the snapshot region is fine, if you have dedicated SMath documents for generating these snapshots. However, if you want to use these documents as parts of the help system (e.g. Activebook) then the current region formatting is a little distracting. Would it be possible to hav an (optional) less dominantly structuring design, lets say like proposed in this post?
#17 Posted : 23 September 2013 00:18:14(UTC)
AFAIK a real frame (with empty body) is not possible with custom regions, but I may be wrong;
To let the region easily editable I can add a control to collapse the region in a smaller one; BTW this don't let you know what's the exported region, so if something change requiring more width or height you need to expand again the region before resizing it...
Edited by user 23 September 2013 02:25:30(UTC)  | Reason: Not specified
#18 Posted : 24 September 2013 02:57:18(UTC)
UPDATED
- compact mode;
- fixed frame position when descriptions are shown.
[edit & updated] - forced transparent background on resizing.
Code:
compact="False"
Edited by user 24 September 2013 13:53:28(UTC)  | Reason: updated
on 25/09/2013(UTC)
Offline mkraska
#19 Posted : 25 September 2013 19:34:12(UTC)
mkraska
I'd propose to expand and collapse the region just by clicking on it. So far, such mouse action would not do anything, thus it would not harm but avoid using the context menu.
#20 Posted : 25 September 2013 20:14:13(UTC)
I can do it, but are you sure? if you want just to resize the region and you go outside the placeholders, the region will resize (just to ask, I agree with the "less things as possible" approach)...
[edit] I'm thinking about a visual change on mouse over...
Edited by user 25 September 2013 20:44:03(UTC)  | Reason: Not specified
Guest (2)
3 Pages123>
