SMath Studio Forum
Samples
A function for finding constrained minimum
Joined: 27/08/2013(UTC) Posts: 19 Was thanked: 9 time(s) in 5 post(s)
Attached is a snippet function for calculating the constrained minimum of a scalar function J(x) of several variables. More specifically it solves the problem: minimize J(x) in the domain xm <= x <= xMsubject to: g(x)>=0; (a vector function of m potentially nonlinear inequality constraints) A*x = b; ( r linear equality constraints, A being an rxn matrix) The algorithm has been adapted from this article (in particular from eqn. (7) on page 4): http://www.ajbasweb.com/ajbas/2011/894-909.pdf. Edited by user 13 September 2013 01:44:41(UTC)
| Reason: Not specified
2 users thanked mb10 for this useful post.
on 12/09/2013(UTC), on 12/09/2013(UTC)
I attached a version with function arguments. In the definition, the formal parameter is a function name with the numbers of arguments given, in the call the actual parameter is the function with an UNDEFINED variable as dummy argument, Thus, minimize(J(x), g(x), x ... won't work because x is bound to the initial values vector. |
@ Martin Kraska:
With your changes (and changing the names in the body of the algorithm as well), it seems to work fine now, and I will soon update both files accordingly.
Thank you very much for your explanations!
mb
The attachments in the first post have been updated according to the suggestions of M. Kraska.
SMath Studio Forum
Samples
