24 Pages«<89101112>»
Offline sija
#181 Posted : 12 years ago
sija
Poland
Originally Posted by: uni Go to Quoted Post
When you are trying to calculate the last expression the maple() function takes the following expression (see mvr5\mvr5.txt):
As you can see: solve({(0=, but you expected solve({(x=. That's the difference. The solve() function solves another equation.
As far as well I understand, you want to say that this is not the Maple error but SMath Studio. Am I right? Please forgive my enquiries.
Janusz
Offline uni
#182 Posted : 12 years ago
uni
Was thanked: 1400 time(s) in 817 post(s)
For now it's not so clear for me where is a problem. I doubt that there is an error. I'm thinking...
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
Offline sija
#183 Posted : 12 years ago
sija
Poland
Uni,
Thank you for the answer. I do not doubt that you will find proper solution.
Best regards,
Janusz
thanks 1 user thanked sija for this useful post.
on 08/06/2013(UTC)
Offline omorr
#184 Posted : 12 years ago
omorr
Serbia
Was thanked: 319 time(s) in 268 post(s)
Hmm..., a peculiar thing hapened to me. Not sure what is it about. Things sometimes change in using maple() by recalculation worksheet.
Here is a simple example I've mentioned before
I do nothing but recalculate the worksheet subsequently. After few (do not know ho many) the results changed and get back. Sometimes "Empty stack..." happened (did not caught it here)
As I am not a Maple user, I might do something wrong of course - but looks strange to me.
Could someone try to reproduce this? Just open the file and press F9 until/if the results changed.
Edited by user 12 years ago  | Reason: Not specified
File Attachment(s):
odesystem.sm (10kb) downloaded 47 time(s).
mvr5.txt (667kb) downloaded 30 time(s).
Offline uni
#185 Posted : 12 years ago
uni
Solutions in the vector may be reversed. I don't know why.
uni attached the following image(s):
Offline omorr
#186 Posted : 12 years ago
omorr
Serbia
You are right. The same is happening when you delete the first system and leave the second one. After after many subsequent F9, you will get the solutions for z(t), u(t) reversed and back.
Offline sija
#187 Posted : 12 years ago
sija
Poland
Again I receive the same type of error. But this time the change the argument's separator from ";" on "," - in the application settings, does not liquidate the appearance of the error. Anybody know what's the reason of this error?
Janusz
Offline omorr
#188 Posted : 12 years ago
omorr
Serbia
File Attachment(s):
opet ode.sm (13kb) downloaded 55 time(s).
opet ode1.sm (12kb) downloaded 52 time(s).
Offline sija
#189 Posted : 12 years ago
sija
Poland
Radovan,
Once again thank you for your perfect help. Unfortunately I do not have the experience with the Maple application, by now I used Derive. However SMath Studio with the MapleWrapper plugin is a splendid programme. I think I must better recognize the Maple language.
The best regards,
Janusz
P.S.
It's a matter of the parenthesis:
on 13/06/2013(UTC)
Offline omorr
#190 Posted : 12 years ago
omorr
Serbia
You are welcome,
By the way, I did not use Maple at all Good , just occasionally used Maxima.
Offline sija
#191 Posted : 12 years ago
sija
Poland
I try calculate the LambertW function as in the after-mentioned example. During calculations I receive the answer: "function is not defined". I found the name of LambertW function in the cmds file of MapleWrapper plug-in, but I'm not sure that the function is implemented in that plug-in. From the prompt of the plug-in or SMath Studio - I'm not sure, results that the function is not implemented in MapleWrapper. Please for the confirmation is that function implemented or not. Maybe I do something improperly?
Janusz
Offline uni
#192 Posted : 12 years ago
uni
The problem in the fractional representation of the numbers.
on 02/07/2013(UTC)
Offline omorr
#193 Posted : 12 years ago
omorr
Serbia
I used the recent unofficial build by Martin Kraska. As we know, there is no Maple plugin there. I installed it of course. It did not work initially. Whatever I tried it returned "empty". Just by chance I moved the entire directory where the SMath portable resides one folder up, then everything was Ok. It seems that maple will not work for me if the directory containing the portable version is to low in hierarchy. Not quite sure about it and what was the reason. Maybe to many spaces in the directory names, maybe to long directory absolute name - do not know.
Offline sija
#194 Posted : 12 years ago
sija
Poland
Uni,
Thank you for the bright and complete answer.Thank you
The best regards
Janusz
Offline mkraska
#195 Posted : 12 years ago
mkraska
I am not able to reproduce the maple plot examples in 4909 any more. maple() runs as usual, just the maple plot region seems to have problems to produce the image files. The temporary files mentioned in the log file are created but empty.
File Attachment(s):
mvr5 (2).txt (3kb) downloaded 29 time(s).
on 08/08/2013(UTC)
Offline mkraska
#196 Posted : 12 years ago
mkraska
SMath crashes when I try to access the context menu of a maple region. The contents of the error message is attached. Using SMath 4909.
File Attachment(s):
error maplescript.txt (16kb) downloaded 29 time(s).
on 08/08/2013(UTC)
Offline uni
#197 Posted : 12 years ago
uni
Fixed.
Do not use this region for now.
on 10/08/2013(UTC)
Offline mkraska
#198 Posted : 12 years ago
mkraska
Thanks a lot, plot works now (still cannot save the script).
Offline mkraska
#199 Posted : 11 years ago
mkraska
There is a problem in SMath with the return format of dsolve solutions from Maple.
After writing the command, you can evaluate just once. Upon recalculation (button in toolbar) control gets lost.
You could either translate the = to boolean equal (this is how we plan to handle that in Maxima)
or translate it into : and thereby immediately defining the solution function. This, however, would provide problems upon recalculation of the sheet. You also might just cut off the left hand side, but that perhaps won't work for systems of equations.
Edited by user 11 years ago  | Reason: Not specified
File Attachment(s):
dsolve.sm (3kb) downloaded 43 time(s).
Offline omorr
#200 Posted : 11 years ago
omorr
Serbia
Just see few posts above please, for instance starting from this one . As I understood uni, there is op() function in Maple for extracting expressions
f(x):maple(op(2,dsolve(diff(f(x),x)+5*x*f(x)≡x^2,f(x))))
f(x)={sqrt(10)*(x*sqrt(10)+i*sqrt(π)*exp(-{5*x^2}/2)*Erf({i*x*sqrt(10)}/2))+50*exp(-{5*x^2}/2)*_C1}/50
thanks 2 users thanked omorr for this useful post.
on 19/09/2013(UTC),  on 19/09/2013(UTC)
