Functions list: AirPTWV(), AirPVWT(), AirTVWP(), AirPTW(), AirPTF(), AirPWD(), AirPTRW(), AirPTWR(), AirPTWB(), AirPTBW(), AirPBWT(), AirPBRT(), AirPTWU(), AirPTUW(), AirPTWH(), AirPWHT(), AirPHWT(), AirPTWS(), AirPWST(), AirPSWT(), AirVapPT(), AirVapTP(), AirCondPTH(), AirCondPTS(), AirPTWM(), AirPTWK(), AirPTWC(), AirPTHs(), AirPHTs(), AirWX(), AirXW(), AirVer(). Dependences: Mathcad EFI plugin. Short description:
AirPTWV - [Mcdair32.dll] [ P, T, W, UnitSet ] returns the specific volume AirPVWT - [Mcdair32.dll] [ P, V, W, UnitSet ] returns the dry bulb temperature AirTVWP - [Mcdair32.dll] [ T, V, W, UnitSet ] returns the pressure AirPTW - [Mcdair32.dll] [ P, T, UnitSet ] returns the saturated humidity ratio AirPTF - [Mcdair32.dll] [ P, T, UnitSet ] returns the enhancement factor AirPWD - [Mcdair32.dll] [ P, W, UnitSet ] returns the dew point temperature AirPTRW - [Mcdair32.dll] [ P, T, R, UnitSet ] returns the humidity ratio AirPTWR - [Mcdair32.dll] [ P, T, W, UnitSet ] returns the relative humidity AirPTWB - [Mcdair32.dll] [ P, T, W, UnitSet ] returns the wet bulb temperature AirPTBW - [Mcdair32.dll] [ P, T, B, UnitSet ] returns the humidity ratio AirPBWT - [Mcdair32.dll] [ P, B, W, UnitSet ] returns the dry bulb temperature AirPBRT - [Mcdair32.dll] [ P, B, R, UnitSet ] returns the dry bulb temperature AirPTWU - [Mcdair32.dll] [ P, T, W, UnitSet ] returns the degree of saturation AirPTUW - [Mcdair32.dll] [ P, T, U, UnitSet ] returns the humidity ratio AirPTWH - [Mcdair32.dll] [ P, T, W, UnitSet ] returns the specific enthalpy AirPWHT - [Mcdair32.dll] [ P, W, H, UnitSet ] returns the dry bulb temperature AirPHWT - [Mcdair32.dll] [ P, H, W, UnitSet ] returns the dry bulb temperature AirPTWS - [Mcdair32.dll] [ P, T, W, UnitSet ] returns the specific entropy AirPWST - [Mcdair32.dll] [ P, W, S, UnitSet ] returns the dry bulb temperature AirPSWT - [Mcdair32.dll] [ P, S, W, UnitSet ] returns the dry bulb temperature AirVapPT - [Mcdair32.dll] [ P, UnitSet ] returns the water vapor saturation temperature consistent with UnitSet AirVapTP - [Mcdair32.dll] [ T, UnitSet ] returns the water vapor saturation pressure consistent with UnitSet AirCondPTH - [Mcdair32.dll] [ P, T, UnitSet ] returns the liquid water specific enthalpy consistent with UnitSet AirCondPTS - [Mcdair32.dll] [ P, T, UnitSet ] returns the liquid water specific entropy consistent with UnitSet AirPTWM - [Mcdair32.dll] [ P, T, W, UnitSet ] returns the dynamic viscosity AirPTWK - [Mcdair32.dll] [ P, T, W, UnitSet ] returns the thermal conductivity AirPTWC - [Mcdair32.dll] [ P, T, W, UnitSet ] returns the specific heat AirPTHs - [Mcdair32.dll] [ P, T, UnitSet ] returns the saturated specific enthalpy consistent with UnitSet AirPHTs - [Mcdair32.dll] [ P, H, UnitSet ] returns the saturated temperature consistent with UnitSet AirWX - [Mcdair32.dll] [ Humidity Ratio, UnitSet ] returns the mole of mass fraction consistent with UnitSet AirXW - [Mcdair32.dll] [ mole or mass fraction, UnitSet ] returns the humidity ratio consistent with UnitSet AirVer - [Mcdair32.dll] [ dummy ] returns the @Air version and serial number
Links: 1. Mcdair32.dll you can get from here: @Air 4.0 (or from archive below). You must manually copy the Mcdair32.dll to the userefi folder (".../Application Data/.../91a20d24-c30b-4774-9b1b-4d502a80420f/x.x.x.x/userefi/" ) and TAir32.dll to the \windows\system32\. Edited by user 19 July 2013 20:25:22(UTC)
| Reason: Not specified File Attachment(s): air.zip (82kb) downloaded 91 time(s). |
