5 Pages123>»
Offline TheWizEd
#1 Posted : 14 July 2010 22:02:00(UTC)
TheWizEd
Was thanked: 19 time(s) in 13 post(s)
I was curious to see how units would be handled in matrices. So I tried a few things and was suprised how well it worked. See screen shot below.
Great job. Well thought out. Remeber everthing is calculated in SI units but comes out fine in US/Imperial units.
Ed
Offline TheWizEd
#2 Posted : 24 October 2010 19:11:53(UTC)
TheWizEd
Another advantage of SMath over Mathcad is for matrix elements to have any units and the math is performed correctly. This matrix and multiplication of its elements is not possible in Mathcad.
Ed
Offline ralfsnell
#3 Posted : 30 August 2012 09:36:03(UTC)
ralfsnell
How do these US units work?
If I take a simple force in kips multiplied by a moment arm in ft
I get result in J....then when I try to change units to kip ft
by adding kip, I get m kip...then when trying to get to kip ft
I get
kgm^2 kip'ft
________________
(s^2)kip'ft
Following from cut and paste....
el(F,1)*el(A,2)=225.97*{'kg*'m^2}/{'s^2*''kipft}@''kipft
Also, how do you get the units outside the matrix? I can only
put units immediately after the cell values.
Thanks for any responses.
Edited by user 30 August 2012 09:39:13(UTC)  | Reason: Not specified
#4 Posted : 30 August 2012 13:58:49(UTC)
Hi ralfsnell,
simply type in the right placeholder
Code:
'kip*'ft
regards,
w3b5urf3r
Edited by user 30 August 2012 14:00:48(UTC)  | Reason: Not specified
File Attachment(s):
U&M.sm (4kb) downloaded 76 time(s).
Offline ralfsnell
#5 Posted : 31 August 2012 18:04:14(UTC)
ralfsnell
Thank you, was trying not to type but rather use the drop-down to insert units.
It appears the "*" was the missing element to that effort.
Appreciate your input and the attachment.
Originally Posted by: w3b5urf3r_reloaded Go to Quoted Post
Hi ralfsnell,
Code:
'kip*'ft
regards,
w3b5urf3r
Offline justhumm
#6 Posted : 19 January 2017 00:45:25(UTC)
justhumm
Rank: Member
When using a matrix with elements of a variety of units, is there a way to control the display of the resulting units (imperial instead of SI units)?
For instance, in the attached image:
k'(1,1) = A(in^2)*E(ksi)/L(in) = kip/inch, but results are in kg/s^2
k'(3,2) = 6 * E(ksi) * I(in^4) / L^2(in^2) = kip, but results are in kg*m/s^2
#7 Posted : 19 January 2017 01:57:29(UTC)
Hello justhumm Offline ,
You can try using
Code:
OutputUnitsSystem=Imperial
instead of
Code:
OutputUnitsSystem=Metric
in
Code:
%APPDATA%\Smath\settings.inf
(it is an experimental feature)
on 19/01/2017(UTC),  on 19/01/2017(UTC)
Offline justhumm
#8 Posted : 19 January 2017 02:51:58(UTC)
justhumm
Rank: Member
Davide Carpi:
Thanks for the response! It seems to be working.
Wishlist item:
It would be nice to have the ability to switch between feet and inches for the default imperial unit. :-)
#9 Posted : 19 January 2017 15:19:54(UTC)
You're welcome Good
Wishlist item:
You can join the [SS-1]
Offline marks2c
#10 Posted : 15 February 2022 00:54:54(UTC)
marks2c
New Zealand
Was thanked: 4 time(s) in 3 post(s)
When using matrices with units the results are given MKS rather than in the input units as shown here:
[img=https://drive.google.com/file/d/1t2xr1KeCbzzOqMVLE_I6mISzGC_4RLwn/view?usp=sharing]Units with Matrices[/img]
What an I needing to do to show the correct units?
Offline overlord
#11 Posted : 15 February 2022 02:46:07(UTC)
Turkey
Was thanked: 510 time(s) in 340 post(s)
- After you calculate and get the result, click on the expression or move your cursor with keyboard to it (Step 1)
- There should appear a placeholder on the result part, write there your desired output unit (Step 2)
- When you press enter or click outside or just loose the focus for expression, your output shall be in your input units (Step 3)
Offline marks2c
#12 Posted : 15 February 2022 04:06:05(UTC)
marks2c
New Zealand
Thank you so much Overload, greatly appreciated.
Offline marks2c
#13 Posted : 15 February 2022 05:08:20(UTC)
marks2c
New Zealand
This is getting so close!
I've tried the plus-minus function, but can't get the min or max element values. I suspect this is because the result isn't a maxtrix:
edit by mod: please use the forum attachment feature; images stored outside the domain soon or leater expires or are removed and the topic becomes unreadable. Thank you.
Or it could be my 'PBCAK' (OSI layer-8) problem...
Edited by moderator 15 February 2022 13:44:43(UTC)  | Reason: Not specified
#14 Posted : 15 February 2022 13:47:55(UTC)
That's the cause, yes. You can use sys2mat() function from custom functions plugin or Max()/Min() functions (uppercase M) from the same extension.
Offline marks2c
#15 Posted : 15 February 2022 21:46:33(UTC)
marks2c
New Zealand
Greatly appreciated Davide. Thank you.
#16 Posted : 16 February 2022 19:40:53(UTC)
Offline marks2c
#17 Posted : 16 February 2022 19:50:49(UTC)
marks2c
New Zealand
Thank you Jean, that is very elegant. What was the function of the red kOHMS:=1?
#18 Posted : 16 February 2022 19:56:11(UTC)
min("matrix"Wink - Returns the smallest element of vector or matrix. If any value is complex, returns min(Re(...)) + i*min(Im(...)).
... Exemplified
2D Plot Discontinuous [min(,)].sm (45kb) downloaded 11 time(s).
Offline overlord
#19 Posted : 16 February 2022 20:28:13(UTC)
Turkey
Actually it is not elegant, very primitive method only used by Jean.
He just continues to try to confuse new users.
He make his own units, not compatible with ISO units.
Which is the case here, he assigned a new red colored Ω to 1. (Ω:=1)
That red Ω is not V/A, ask him to divide it to volts. He won't get 1/Amper.
Don't use his methods, them are just bad practices.
thanks 2 users thanked overlord for this useful post.
on 24/02/2022(UTC),  on 12/03/2022(UTC)
Offline overlord
#20 Posted : 16 February 2022 21:05:33(UTC)
Turkey
Jean's math is unitless crusade is garbage.
We don't only do pure math calculations.
Engineering and science needs units.
As I have said before;
Math is unitless, science/engineering is not.
Jean's "silence unit" crap is useless, confusing.
As it is shown below.
5 Pages123>»
