SMath Studio - SMath
They talk about us
It's perfect alternative to Mathcad. The solution to make another namespace for measure units - is genious!
more...
by Sergey Grunenko
Smath is easy to use tool and its is freeware.I used for engineering calculations instead of easing excel. Its a time saver.
more...
by Naresh varikuntla
beautiful strument
more...
by michele
4 users thanked Andrey Ivashov for this useful post.
on 08/03/2021(UTC), on 08/03/2021(UTC), on 09/03/2021(UTC), on 10/03/2021(UTC)
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 830 time(s) in 526 post(s)
Hi. Thanks for the program, and this update. An small issue: Write some text and then put the cursor somewhere in between within that text and hit the right-delete key. When you reach the end of the text, the work DELETE begins to appear several times: Best regards. Alvaro.
Joined: 23/07/2013(UTC) Posts: 1,129 Was thanked: 510 time(s) in 340 post(s)
Originally Posted by: Razonar I can easily reproduce it. What a funny bug, can't keep myself to print several DELETE. Somebody stop me
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 127 time(s) in 82 post(s)
Yes. Edited by user 08 March 2021 15:39:06(UTC)
Oops... I did it again I've spent so many time on backward compatibility, performance and formatting improvements... even forgot to check the simplest use cases. Sorry. Will fix it asap. Actually I'm starting to prepare to make a stable release, so I do not plan to do any major code changes until it is done. Small fixes/corrections only. Thank you!
7 users thanked Andrey Ivashov for this useful post.
on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 27/03/2021(UTC)
