Offline Italo Rebouças
#1 Posted : 16 March 2024 10:58:00(UTC)
Italo Rebouças
Rank: Member
Brazil
I have a question regarding the use of the plugin FEBeam. I downloaded some examples given by the plugin's creator, JC Mendonza, but couldn't reproduce it. When i try to add a point load, the following message(Portuguese) appears:
"O índice está fora do intervalo. Ele deve ser não-negativo e menor que o tamanho da coleção. Nome do parâmetro: index", which translates to:
"The index is outside the interval. It must be non-negative and smaller than the collection size. Parameter name: index".
I don't understand why this is occurring, since the load is applied at a positive position that is smaller than the beam length.
Could someone help me with this?
Thanks in advance.
#2 Posted : 19 March 2024 00:16:07(UTC)
Was thanked: 1338 time(s) in 878 post(s)
Most likely a out of range index issue in the code. The plugin is closed source, so you have to contact directly the developper.
Offline JC Mendoza
#3 Posted : 19 April 2024 07:44:49(UTC)
JC Mendoza
Philippines
Was thanked: 5 time(s) in 1 post(s)
Thanks in advance.
Looking at the snapshot, the error is because no beam has been created in the code. The functions, "A_AddBeam" and "A_AddSupport" need to run by evaluating them. The function should return 1, which means "true" in the code behind that it has been executed. Put equals in the formulas for example: A_AddBeam(_,_,_,_) = 1. Though not sure why smath does not evaluate if you dont put "=".
Best,
JC Mendoza
#4 Posted : 27 April 2024 02:26:07(UTC)
Italo Rebouças
Rank: Member
Brazil
Thanks Mr. Mendonza.
Guest (2)
