Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 830 time(s) in 526 post(s)
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,495 Was thanked: 1275 time(s) in 746 post(s)
Originally Posted by: mkraska BTW, how about making the glyph of the mathcad block reflect the actual type by using {,[ or | to indicate the vertical extension? I haven't done this yet because I want the user to be able to choose the type of lines. For all sides. Edited by user 18 April 2023 16:13:20(UTC)
Originally Posted by: mkraska Unfortunately, I can't reproduce your parametric plot example. It seems that the parameter range is taken from the x axis limits. Assigning a range to the parameter makes the plot fail.
How to fix this? Links: 1. Added support for parametric plot type |
Theoretically, I can get data from any component. I can try to get the text from the text region. |
Originally Posted by: uni Theoretically, I can get data from any component. I can try to get the text from the text region.... Amazing: That's true for a lot of components! What about to catch the text in your memo editor instead SMath's text regions? Or both, I don't know. Best regards. Alvaro.
Originally Posted by: Razonar Amazing: That's true for a lot of components! What about to catch the text in your memo editor instead SMath's text regions? Or both, I don't know. It's funny, I haven't tried it. I want to simplify the input of text programs. This is another way to extend the functionality of the program through third-party libraries. A lot of useful libraries have been developed now. There is no point in repeating all this. It is necessary to create flexible interfaces for their integration and interaction with each other. |
Originally Posted by: uni ... I want to simplify the input of text programs. ... Yep. It would be very practical to have a tool to capture text to process it. I try to use description() function, but it has the drawback that it must be called at the worksheet level and it doesn't work well within the body of a function. Like in chess, RPN, Code or XYOptions. Best regards. Alvaro.
on 30/04/2023(UTC), on 30/04/2023(UTC)
Plugin updated. Changes: - MathcadBlock: added support for function definition. Now the function definition can be written directly in the block. maple-system-execute.sm (9kb) downloaded 27 time(s).Memo Region also supported but it has not been updated for a long time, so some of its text functions do not work. Edited by user 30 April 2023 19:43:28(UTC)
Is there a chance to at least partially use units here? The values with units are disabled in the sheet, this is not visible in the png-file. 7-1.sm (30kb) downloaded 9 time(s). |
Originally Posted by: mkraska Is there a chance to at least partially use units here? This is an option for having partial and full units support. 7-1-units.sm (36kb) downloaded 8 time(s).Best regards. Alvaro. Edited by user 25 November 2023 19:28:32(UTC)
on 26/11/2023(UTC), on 26/11/2023(UTC)
Alvaro, thanks for the hints. By whatever reason, the unit of the independent variable is respected in rkfixed()=even though it is set to 1 locally. Whatever locally means if that happens in the last input parameter value. 7-1_units.sm (40kb) downloaded 5 time(s). |
Hi Viacheslav. It seems that there is some issue with Rkadapt and fixed that other solvers doesn't have. dint - Rkadapt bug.sm (25kb) downloaded 6 time(s).Best regards. Alvaro.
on 16/05/2024(UTC), on 17/05/2024(UTC)
Indeed, this is strange, because the source code should be very similar for all solvers. I'll try to find the differences. |
Using ode solvers for evaluate double integrals. dint-RK.sm (50kb) downloaded 4 time(s). dint-RK.pdf (198kb) downloaded 11 time(s).Best regards. Alvaro.
on 18/05/2024(UTC), on 18/05/2024(UTC)
