Please post here any bug you found or any feature you want to see in SMath Studio.
Moderators:
Administrators
SMath crashes when opening a project
the problem with the text region
aiv_x
27/11/2021 11:53:40(UTC)
1
333
28/11/2021 13:15:40(UTC)
SMath File Crashes Automatically
metu_engineer_1
17/11/2021 02:11:12(UTC)
4
674
17/11/2021 03:39:03(UTC)
Connection terminated // Plugins
Warning Connection terminated.
[+1]
Lelar
13/09/2021 00:56:58(UTC)
5
784
MarB
16/11/2021 15:06:16(UTC)
[SS-4676] (-1) with Decimal Exponents
A Serious Bug
08/11/2021 20:12:28(UTC)
4
665
11/11/2021 16:07:15(UTC)
File path issues with importData(2)
Import file path string gets corrupted when re-opening sMath file
tedd
08/11/2021 19:30:35(UTC)
0
234
tedd
help funtions Smath
Mohr-Coulomb circle
LeonardoPereira
04/11/2021 15:16:12(UTC)
3
476
04/11/2021 21:29:40(UTC)
Problem with variables
Lelar
04/11/2021 05:48:49(UTC)
2
348
04/11/2021 15:28:46(UTC)
Output widnow issue
piotr_Te
15/10/2021 17:58:25(UTC)
1
399
17/10/2021 16:40:42(UTC)
TextRegionUtilities - Could not load file or assembly 'WriterRegion
Cannot install or disable TextRegionUtilities
Tim Gowing
14/10/2021 12:54:45(UTC)
3
383
Tim Gowing
14/10/2021 17:14:36(UTC)
multi-rename
multi-rename (with F8) not working?
rdsignr
09/10/2021 13:17:46(UTC)
0
225
rdsignr
Header Disappears
Header disappears when closing and reopening file
D A 123
06/10/2021 18:19:51(UTC)
1
293
D A 123
06/10/2021 18:37:36(UTC)
Snippets definition
Snippets need to be saved in the correct folder to work
pisker
05/10/2021 15:56:43(UTC)
0
274
pisker
Cannot drag elements onto another page
bugreportaccount
20/09/2021 07:53:50(UTC)
0
241
bugreportaccount
strange behavior with units
"var not defined" when attach a temperature unit
oscampo
16/09/2021 17:54:48(UTC)
3
423
alyles
17/09/2021 23:30:10(UTC)
Latest SS 0.99.7921.69 - XYPlot fonts enlarged
ndtma
11/09/2021 18:52:56(UTC)
2
365
uni
12/09/2021 01:44:15(UTC)
Guest (2)
New Posts |
No New Posts |
Hot Topic (New Posts) |
Hot Topic |
New Posts (Locked) |
No New Posts (Locked) |
Announcement (New Posts) |
Announcement |
Sticky (New Posts) |
Sticky |
Poll (New Posts) |
Poll |
Moved |
