Please post here any bug you found or any feature you want to see in SMath Studio.
Moderators:
Administrators
if(...) not correct shown in Win11
Bug in if(...) function
Thilo
25/07/2022 20:54:34(UTC)
3
637
shafiq ur rehman
01/08/2022 21:04:29(UTC)
Table Problems, Possible bug?
ianlh
28/07/2022 12:59:37(UTC)
2
293
ianlh
28/07/2022 13:36:30(UTC)
Text Region Background Color
Bug when it contains a formula
07/01/2022 20:18:23(UTC)
8
811
24/07/2022 01:33:57(UTC)
[SS-3567] File corrupted after using region protection option
cecile
03/10/2018 19:07:21(UTC)
4
1,131
MauroMen
15/07/2022 05:21:58(UTC)
Solution of Equation "no real roots" result
Fog123
06/07/2022 22:26:55(UTC)
10
751
11/07/2022 20:05:45(UTC)
[OpenSuse] symbols not showing properly on screen
charlamb
30/06/2022 21:49:24(UTC)
6
688
04/07/2022 22:39:24(UTC)
issue with new functionality "Defined integral supports units"
PompelmoTell
25/06/2022 22:23:26(UTC)
2
325
PompelmoTell
26/06/2022 18:13:48(UTC)
Problem with Region Table Plugging
miguel sambrano
22/06/2022 17:06:09(UTC)
2
375
miguel sambrano
23/06/2022 16:26:39(UTC)
Maxima Draw2D labels error
Errors on labels on Draw2D from Maxima
DiegoV
14/06/2022 07:52:42(UTC)
11
1,212
mkraska
18/06/2022 00:21:04(UTC)
Text characters not passing correctly to Maxima plugin
Text like "RED,red RED" is sent to Maxima as "RED'002C'red'0020'RED"
[+4]
gurro
15/08/2021 00:14:03(UTC)
4
787
DiegoV
15/06/2022 09:18:14(UTC)
wiki overwritten by non-SMath content
there is non-SMath content at the wiki url
Joe Cahill
21/04/2022 06:48:24(UTC)
4
543
27/05/2022 11:18:41(UTC)
Snippet Operations with units Fail
Fails on some occasions to detect the units
CBG
17/05/2022 01:05:41(UTC)
7
789
19/05/2022 14:28:50(UTC)
I can't access Maxima tools
api-ms-win-core-synch-l1-2-0.dll dynamic link library is not found
yeyu
19/05/2022 06:48:56(UTC)
1
497
Razonar
19/05/2022 14:23:41(UTC)
Accuracy problem with boolean operator
Boolean operation fails due to accuracy
janclaeys
12/05/2022 16:05:24(UTC)
5
508
janclaeys
13/05/2022 15:53:18(UTC)
Variables with text in Smath Viewer
Smath Viewer does not change variables that contain text
CBG
28/04/2022 01:27:22(UTC)
0
337
CBG
Guest (4)
