Sub-forums
  Forum Topics Posts Last Post
No New Posts
Please post here any bug you found or any feature you want to see in SMath Studio.
Moderators: Administrators
72 Pages«<23456>»
Bugs & Problems - Here you can inform the developers about issues you found out
  Topics Replies Views Last Post
New Posts Issue Problem on Ubuntu 22.10
Raymond Reddington , 24/01/2023 15:59:51(UTC)
6 620 overlord Go to last post Go to first unread
26/01/2023 18:38:54(UTC)
New Posts Error in generating exe and using plugin
Error in generating exe and using plugin in sheet
johnnyontheweb , 22/09/2021 17:36:55(UTC)
4 540 johnnyontheweb Go to last post Go to first unread
19/01/2023 13:05:35(UTC)
New Posts Snippet does not display files in folder
TIAGO_ENG2012 , 10/01/2023 01:12:16(UTC)
0 127 TIAGO_ENG2012 Go to last post Go to first unread
New Posts "Structural Beam Analysis" plugin error
Index outside matrix boundaries error
Eneko , 16/01/2020 16:58:36(UTC) - [ Go to Page:  ] 1 , 2
27 2,757 uni Go to last post Go to first unread
04/01/2023 13:10:05(UTC)
New Posts Issue Reverse order of words in Hebrew
RomanG , 07/12/2022 20:19:51(UTC)
4 575 Jean Giraud Go to last post Go to first unread
20/12/2022 14:24:28(UTC)
New Posts Plugin installation fails
Multiple plugins fail to install
CBG , 14/12/2022 05:43:51(UTC)
3 289 Davide Carpi Go to last post Go to first unread
15/12/2022 12:35:28(UTC)
New Posts Solved Recursive functions not working
S0lo , 30/11/2022 14:53:58(UTC)
8 589 Razonar Go to last post Go to first unread
02/12/2022 04:09:52(UTC)
New Posts Fixed snippets exception in version 0.99
snippets exception
Raul Menduina , 04/06/2021 13:27:48(UTC)
4 446 Raul Menduina Go to last post Go to first unread
01/12/2022 18:50:56(UTC)
New Posts Unit or user error?
Roger Andersson , 29/11/2022 15:31:40(UTC)
3 190 Roger Andersson Go to last post Go to first unread
29/11/2022 17:15:12(UTC)
New Posts Question problems with physical units and calculations
rsdias , 17/11/2022 13:27:15(UTC)
3 272 rsdias Go to last post Go to first unread
17/11/2022 17:23:12(UTC)
New Posts Informative X_Y ...
X_Y ...
Jean Giraud , 01/11/2022 14:05:51(UTC)
6 471 uni Go to last post Go to first unread
07/11/2022 09:59:19(UTC)
New Posts Issue Bug inverting matrices
Inverting a matrix gives inconsistent answer
David R , 28/10/2022 04:51:20(UTC)
11 471 Jean Giraud Go to last post Go to first unread
28/10/2022 21:44:31(UTC)
New Posts wiki pages
stefanodel , 24/10/2022 16:05:44(UTC)
1 216 Davide Carpi Go to last post Go to first unread
25/10/2022 15:23:51(UTC)
New Posts Inconsistent unit handling
seemingly identical definitions result in different display of units
mkraska , 08/10/2022 14:39:35(UTC)
0 242 mkraska Go to last post Go to first unread
New Posts Issue fonts in Linux (OpenSuse)
Many fonts do not show and some greek letters are missing
jkegmxde , 03/09/2022 12:20:14(UTC)
1 296 overlord Go to last post Go to first unread
04/09/2022 02:15:48(UTC)
Users browsing this forum
Guest (2)
Show Topics Mark this forum as read
72 Pages«<23456>»
Search Forum    OK
New Posts No New Posts
Hot Topic (New Posts) Hot Topic
New Posts (Locked) No New Posts (Locked)
Announcement (New Posts) Announcement
Sticky (New Posts) Sticky
Poll (New Posts) Poll
Moved
