Offline TheWizEd
#1 Posted : 07 June 2011 23:42:38(UTC)
TheWizEd
Was thanked: 19 time(s) in 13 post(s)
I was curious how to embed matrices in a matrix and access an element of it.
X[2 gives me the second row matrix.
(X[2)[1,2 gives me the middle element of the second row.
Works with functions too.
Open in SMath Cloud
Ed
Offline omorr
#2 Posted : 08 June 2011 09:36:28(UTC)
omorr
Serbia
Hello Ed,
Yes, that is possible in SMath. One can have nested-embedded matrices. Andrey introduced that in one of the previous releases. I think he intended to apply some operations with so called "block matrices". It seems that there is some additional work to be done regarding this. It depends on Andrey's opinion about that.
For instance, take a closer look to this example.
Open in SMath Cloud
Did you notice how transpose operator works with nested matrices?
On the other hand, we should take care of the multiple indexing here in order not to make mistakes.
Edited by user 08 June 2011 15:00:35(UTC)  | Reason: Not specified
on 08/06/2011(UTC)
Offline TheWizEd
#3 Posted : 08 June 2011 19:31:49(UTC)
TheWizEd
Radovan,
I'm not able to sub element an element thats why I found I had to enclose the submatrix in parens (X.2)[1,2 to get it to work. I'm using 0.89. Perhaps in the beta versions you can sub element an elemnt of a matrix X[2[1,2.
Ed
Offline omorr
#4 Posted : 08 June 2011 22:49:32(UTC)
omorr
Serbia
Hello Ed,
At the moment, we should take care when using this multiple indexing. You could use parenthesis, but you do not need to do that if you use space key {SPACE}. For instance you should use X[2{SPACE}[1,2 instead of X[2[1,2. If we do not take care of this {SPACE} thing, there would actually error be issued - sometimes a strange one, for instance - that we try to display some large or small number not supported by Int32 ??? . There would be no problem as long as we use {SPACE} to enclose the needed parts of the variable inside the editing line (where invisible parenthesis would actually be). As I said, I think there are some additional efforts needed by Andrey to resolve these ambiguities.
I hope I made myself understood. If not I would give some pictures in the subsequnt posts (not able at the moment).
Offline TheWizEd
#5 Posted : 09 June 2011 02:15:22(UTC)
TheWizEd
Radovan,
I tried your {SPACE} and it works with 0.89 Stable. I didn't know about this. Thanks.
Ed
