Hello Henry, register wrote:1. The column labeled "T" is a column of torque values for different gears. Smath won't simplify the units from kg*m^s/s^s to N*m on its own. I've run into this before when writing out equations, but have always been able to delete the units and replace them with my simplified version. In the matrix, any attempt to modify a cell causes the matrix to collapse and is not allowed. Is there a way to force a column to display certain units? As far as I know, there is no way to simplify or to change units of matrix elements. You can just extract and display a row or column and change the units for the entire row/column Open in SMath Cloudregister wrote:2. .... I then created a matrix called ω (visible in the second image) and stored the results in it, which I then inserted into the matrix called "result1." Instead, I'd like to put all the equations directly into "result1" without having to use the secondary "ω" matrix and the loose equations, but when I try to type anything into the pre-existing matrix, it collapses and won't let me enter anything. Is the only way to do this by defining the size of the matrix before I enter anything into it? I am not sure if I understood this well, but here is something you can use - multiline definitions: Open in SMath CloudInside the line() environment you can define some calculation and matrix "result" will receive the value of the variable in the last line ("together" in this case). Any defined variables inside line() (i, name, first, second, together in this case) are locally defined and not known outside that line. But inside line you can get the variables defined outside that line() (nrow in this case) register wrote:3. Is there a way to simplify the "for k ∈ 1..." expressions in the second image? I copied the original syntax from one of the example files called "GravitationAcceleration.sm" and am having trouble understanding how I'd write the expression from scratch, and more specifically if it is possible to use a single "for k ∈ 1..." expression followed by a series of el(result1,k,2)←d.p(el(data,k,2)) expressions? I think that the same is with this question - just try multiline definition of variables and functions res1←line(for(k,range(1,3),line(el(res,k,1)←4*k,el(res,k,2)←9*k,el(res,k,3)←11*k,3,1)),res,2,1)res1=mat(4,9,11,8,18,22,12,27,33,3,3)register wrote:4. Is it possible to populate a single cell of a matrix from an equation? For example, if I had a 3x3 matrix called "matrix," would it be possible to define something like "matrix.3,2 := (4*9)3x" so that if x were to change the matrix location (3,2) would automatically update to the result of the equation? I've searched the excellent .pdf that Dr. Urroz produced but can't find anything exactly like it I did not understand this, sorry. Although I did not understood quite well all of you questions,I hope this would help. Regards, Radovan |
