SMath Studio Forum
Download SMath Studio
Archive
Stable: SMath Studio 0.98.6484 (02 October 2017)
Hello, I've found an issue with the lower indexes (usually after modifying indexes):  Sometimes I couldn't copy part of formula to other formula, because I got an error message. I use Hungarian international settings (decimal point is the comma), and the last SMath Studio version (v0.98 build 6484). Here is a sample: Issue with Lower Index.sm (5kb) downloaded 40 time(s).Best regards Peter Kaderasz P.S. Can we have built-in Moment unit in SMath Studio (Nm)? I have to declare in all my SM file it, as you can see in my attachement. Peter Kaderasz
Joined: 04/07/2015(UTC) Posts: 5,051  Was thanked: 809 time(s) in 642 post(s)
Originally Posted by: kadpeter  I've found an issue with the lower indexes (usually after modifying indexes):
make sure you don't confuse index/subscript Issue with Lower Index.sm (11kb) downloaded 39 time(s).
Joined: 15/04/2012(UTC) Posts: 1,647  Was thanked: 915 time(s) in 575 post(s)
A colleague of mine experienced problems with a high res screen: SMath Studio: SMath Studio Desktop 0.98.6484.11448, portable, x86 OS: Microsoft Windows NT 6.2.9200.0 (Windows 10 Enterprise 2016 LTSB , x64) Screen: 3200x1800 px, 96x96 dpi, 96 GP.DPI, 1 GP.SRF Localization: separator=<semicolon>; decimal symbol=<comma>; system decimal symbol=<comma>; language=ENG Frameworks: CLR 2.0.50727.8766 installed versions: v2.0.50727 2.0.50727.4927 SP2 v3.0 3.0.30729.4926 SP2 v3.5 3.5.30729.4926 SP1 v4 Client 4.7.02053 Full 4.7.02053 v4.0 Client 4.0.0.0 BTW, he also downloaded build 6528. This worked but he couldn't change any option (recoverable soft crash)  |
Joined: 25/11/2017(UTC) Posts: 8   Location: Bucharest
Originally Posted by: Davide Carpi  a big thankyou. in image are books. i switched to "Online gallery" and then i downloaded all. from now i knew about existences of "Writing your first plug-in for SMath Studio Desktop". can you please tell us how we can use freeBasic , https://www.freebasic.net/ , it was recomadated to write plug-ins for trueSpace , http://www.flat2d.com/Truespace_en.aspx . OBS: Button "THANK" not work for me. i use Google Chrome |
remember mathematics |
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,321   Location: Italy Was thanked: 1167 time(s) in 768 post(s)
Originally Posted by: mkraska  A colleague of mine experienced problems with a high res screen: 99% this issue is about the image edit region plugin, I think the fix was compiled and published just for the latest nightly build; remove it and everything should looks as expected. Originally Posted by: mkraska  BTW, he also downloaded build 6528. This worked but he couldn't change any option (recoverable soft crash) If you mean the options in the settings it might be one of the issues already reported in the dedicated topic (otherwise he should be more precise) Originally Posted by: electro  a big thankyou. in image are books. i switched to "Online gallery" and then i downloaded all. You're welcome  Originally Posted by: electro  from now i knew about existences of "Writing your first plug-in for SMath Studio Desktop". can you please tell us how we can use freeBasic I'm not familiar with freeBasic, but bascally you can write a Wrapper in C# or VB.NET that links a library compiled in freeBasic, or you should write a plugin in freeBasic that implements the interfaces of SMath studio (f.e. there is something made in C++ in our SVN repository) Originally Posted by: electro  OBS: Button "THANK" not work for me. i use Google Chrome It should be because some sort of antispam filter in the forum, once you have enough posts (or thanks?) it should works. Edited by user 29 November 2017 05:42:38(UTC)
Originally Posted by: Davide Carpi  Originally Posted by: electro  OBS: Button "THANK" not work for me. i use Google Chrome It should be because some sort of antispam filter in the forum, once you have enough posts (or thanks?) it should works. see the attachment: <> en.smath.info.says: Error Occurred  </> |
SMath Studio Forum
Archive
