  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,589   Was thanked: 1913 time(s) in 652 post(s)
New Beta SMath Studio 0.98.6325 is available!Tiny, but powerful mathematical program with WYSIWYG editor and complete units of measurements support. It provides numerous computing features and rich user interface translated into about 40 different languages. Application also contains integrated mathematical reference book. Changes introduced in current buildImprovements- Built-in function Clear(..) implemented to remove variables/units/functions defined above on the Worksheet;
- SS-2430: Dynamic Assistance tooltips improved: description of the snippet is now shown, footer can be multiline now, functions without description handled correctly;
- Worksheet opening performance improved for Regions with hidden input part;
- Internal meta-data for Regions supported (within the program and worksheet files format).
Corrections- SS-2429: Loading of Worksheet files with self-closing REGION tag(s) fixed;
- Document title corrected on printing (important for some printers).
Miscellaneous- SS-2290: DEV: IPluginToolboxGroups implemented;
- DEV: Initial support for Menu Extenders plug-ins added (IPluginMenuExtender - for always visible items in context menu only);
- DEV: Added ability to remove definitions from the global context;
- Interface translations updated;
- Refactoring.
DownloadEdited by user 26 May 2017 00:43:13(UTC)
| Reason: Not specified
on 26/04/2017(UTC), on 26/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 28/04/2017(UTC), on 29/04/2017(UTC)
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,487   Location: Italy Was thanked: 1239 time(s) in 819 post(s)
Originally Posted by: Andrey Ivashov  Built-in function Clear(..) implemented to remove variables/units/functions defined above on the Worksheet; Function Clear(...) previously available in Custom Functions plugin removed from that extension (from this version of SMath Studio onwards) Edited by user 28 April 2017 13:37:08(UTC)
Joined: 28/04/2017(UTC) Posts: 2  Was thanked: 1 time(s) in 1 post(s)
Due to wrong dpi detection, the user interface is inconsistent, the Contents of the ui Areas are too snall and don't match the actual pointer Location. The screenshot is made on a win10 13" macbook pro with definitly not 96dpi.
Originally Posted by: letzm  Due to wrong dpi detection, the user interface is inconsistent, the Contents of the ui Areas are too snall and don't match the actual pointer Location.
The screenshot is made on a win10 13" macbook pro with definitly not 96dpi. I guess you have to remove image region plugin. |
 1 user thanked letzm for this useful post.
Joined: 15/04/2012(UTC) Posts: 1,723  Was thanked: 950 time(s) in 602 post(s)
Clear() doesn't work with vectorize(), whereas IsDefined() does. It is not really essential to have that feature but the response indicates successful execution, which is wrong. Clear.sm (30kb) downloaded 50 time(s).![2017-04-29 14_01_35-SMath Studio 0.98.6325 - [Clear.sm].png](/forum/resource.ashx?a=16764&b=2) |
Joined: 04/07/2015(UTC) Posts: 6,077  Was thanked: 889 time(s) in 717 post(s)
Hello Martin, Clear(,)=1 looks a Matlab code that clears the work space from previous assigned values. Thus, it renders the algorithm of the "work space" scalar wrt their respective scalar running iterators x, y ... In the attached "Fourier Quantum"... x,y are returned scalar only for the double integrator. The Mathcad double integrator is coded implicit of 'x,y' scalar ... much simpler but less educative. Jean Fourier Quantum CoC Copy.sm (98kb) downloaded 57 time(s).
