SMath Studio Forum
Download SMath Studio
Archive
RC4: SMath Studio 0.98.6103 (16 September 2016)
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,598   Was thanked: 1953 time(s) in 658 post(s)
Release Candidate: SMath Studio 0.98.6103 available - Critical stack overflow exceptions which may appear f.e. because of dead loops in definitions fixed;
- SS-2405: Expressions drawing issues on print out in case of non-standard DPI fixed;
- Handling of sum(..) function corrected to improve back-compatibility;
- Fixed multiple issues with not refreshed Regions (in different cases: on Region focused, on collapsed Area text changing and in some cases on click into Region located after collapsed Area);
- Handling of TAB/Shift+TAB keyboard buttons improved to take into account invisible Regions and current cursor position on the Worksheet;
- Fixed issue appears for some third-party regions when calling for context menu;
- Warnings about usage of time(..) and random(..) functions implemented for worksheet testing in silent mode;
- Refactoring.
Download
 7 users thanked Andrey Ivashov for this useful post.
on 16/09/2016(UTC), on 16/09/2016(UTC), on 16/09/2016(UTC), on 16/09/2016(UTC), on 17/09/2016(UTC), on 17/09/2016(UTC), on 17/09/2016(UTC)
Most likely it is a latest release candidate prepared before new stable release. I expect no any significant changes will be done since today to be sure next build will be stable and tested enough.
Best regards, Andrey Ivashov.
Joined: 29/09/2016(UTC) Posts: 2   Location: Красноярск Was thanked: 4 time(s) in 2 post(s)
In the last versions of SMath Studio last value of range(3) is lost in most cases: Presumably, range(3) works correctly if the first value = 1, or the step = 0,5 or 1: range(1, 3, 1.2), range(2, 4, 2.5), range(2, 6, 3) In other cases it behaves not like range [a;b] but like interval [a;b ) : range(2, 4, 2.2), range(1, 2, 1.1)  Edited by user 29 September 2016 05:12:20(UTC)
| Reason: Not specified
 2 users thanked pavel_n for this useful post.
on 29/09/2016(UTC), on 30/09/2016(UTC)
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,503   Location: Italy Was thanked: 1257 time(s) in 827 post(s)
Thank you
pavel_n
seems there is really a bug Andrey has fixed it, change will be available in the next relase  Edited by user 29 September 2016 15:03:15(UTC)
SMath Studio Forum
Archive
