Offline Andrey Ivashov
#1 Posted : 22 July 2016 03:00:40(UTC)
Was thanked: 1814 time(s) in 616 post(s)
SMath Studio 0.98.6047 available
Latest changes (against SMath Studio 0.98.5997)
  • Updating of Scrollbar Bookmarks fixed on region Delete and Undo/Redo operations;
  • Performance significantly increased when opening worksheets (invisible Regions do not call for invalidation of the worksheet anymore);
  • SS-2325: Scrollbars related multithreading issue appeared sometimes when working with scrollbars fixed;
  • Initial implementation of the built-in debugging tools completed (set breakpoint [Ctrl+F8 or context menu] and recalculate a worksheet);
  • Pause button is available on main toolbar now - it allows to pause calculation and see an exact place where calculation is in progress;
  • Plug-in name included into the Tooltip for functions/variables/operators;
  • Arctan2() function implemented (see known issues below).
Updated 22 July:
  • All breakpoints shown on the vertical scrollbar now, even if they are all in the same region;
  • Issue regarding plug-ins back-compatibility related to debugging fixed;
  • Context Menu with Copy button implemented for the list in Watch panel;
  • Fixed issue when unwanted selection appeared sometimes on debugging;
  • Errors appeared during calculation immediately displayed on vertical Scrollbar now.
Updated 24 July:
  • Tooltips implemented for items in Watch panel;
  • Calculation logic improved for better support of existing worksheets created by previous SMath Studio versions;
  • Critical issue fixed appears on opening Dynamic Assistance list without any Evaluable Region before the cursor;
  • Plug-ins related back-compatibility issue fixed.
Known issues
  • Debugging: Hotkeys for debugging not assigned yet (except Ctrl+F8 for toggling breakpoints);
  • Debugging: Breakpoints set on numbers may not work;
  • Calculation: Function atan(2) has couple of issues;
  • Backcompatibility: Some of the worksheets will not be correctly recalculated still (issue related to undefined variables in definitions).
  • Interface translation: Some strings is not translated yet (they even not registered in translation service).
Download
Edited by user 25 July 2016 02:17:57(UTC)  | Reason: Not specified
thanks 9 users thanked Andrey Ivashov for this useful post.
on 22/07/2016(UTC),  on 22/07/2016(UTC),  on 22/07/2016(UTC),  on 22/07/2016(UTC),  on 22/07/2016(UTC),  on 22/07/2016(UTC),  on 22/07/2016(UTC),  on 22/07/2016(UTC),  on 24/07/2016(UTC)
#2 Posted : 22 July 2016 21:01:31(UTC)
Updated with new links to the corrected build (plug-ins back-compatibility fixed).
on 22/07/2016(UTC),  on 23/07/2016(UTC),  on 23/07/2016(UTC),  on 23/07/2016(UTC)
#3 Posted : 25 July 2016 02:06:23(UTC)
Updated with new links to the corrected build. Plug-ins back-compatibility fixed: http://en.smath.info/for...-file-in-SS-98-6047.aspx
thanks 3 users thanked Andrey Ivashov for this useful post.
on 25/07/2016(UTC),  on 25/07/2016(UTC),  on 25/07/2016(UTC)
Offline Ahmad Allawi
#4 Posted : 01 August 2017 12:09:22(UTC)
Ahmad Allawi
Iraq
Sir,
This is not related to your topic. But simply I have a simple question.
If I would like to upload a worksheet, how this can be done?.
Kind regards.
Ahmad Allawi
Retired Consultant Electrical Engineer-Lecturer
PTC Community Member-4009681/Mathcad Prime2.0 and 15-M10
+9647507473739 and +9648963122
Iraq
#5 Posted : 02 August 2017 02:09:01(UTC)
Was thanked: 842 time(s) in 672 post(s)
Example: in the conference "Questions" click on "New topic"
that will bring the line menu up there,
click on "trombone symbol" ... upload a new file,
double click in the work sheet in your system.
Finally, click on "Upload", then "Post" below.
You can proceed same way in any of the conference [Samples, Bugs ...]
Cheers, Jean
