Is this supposed to take over 5 minutes to calculate? May be SMath as this is the second sheet today that "locks-up" with the calculation tool bas and the timer running
Originally Posted by: ElSid Is this supposed to take over 5 minutes to calculate?May be SMath as this is the second sheet today that "locks-up" with the calculation tool bas and the timer running[/quote Re-download in case something got wrong in the transmission. XP Home, 1.8 GHz, Smath 5346 OFFicial release => 5 seconds Jean Inst_Viscosity Water.sm (53kb) downloaded 84 time(s).Would be interesting more collabs test the timing, thanks.
