  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,101   Was thanked: 972 time(s) in 557 post(s)
Joined: 01/08/2010(UTC) Posts: 115   Location: Rome Was thanked: 13 time(s) in 13 post(s)
thanks a lot for your posting and sorry for the stupid question but how can I install it. I have copied the 2 .dll under the plugin dir but when SmathStudio starts I receive several error messages and the plugin is not loaded.
Thanks in advance for your help and your efforts to improve smath.
Francesco
  Rank: Administration Groups: Registered, Administrators, Advanced Member Joined: 23/06/2009(UTC) Posts: 1,735   Was thanked: 313 time(s) in 267 post(s)
The same question, I also do not know how to make this plugin to work and which one of the dll's from this archive to use and how. I assumed that I have to copy everything under "plugins" folder in this archive into "plugins" folder of SMath. As Francesco mentioned, severeal error boxes appeared. This is obviously wrong regarding the dates (from 2009) of some of the approprriate dll's (or not?). Here is one of the error boxes:  Is there maybe some mess with Mathcad's system of user made functions via dll's? Regards, Radovan |
I'm thinking... Quote:I have copied the 2 .dll under the plugin dir Yes, that's right. It's simple to install. |
Try these dlls: mcadefi_20101123.7zI don't know where a problem. All works for me. mcadefi.dll and mcaduser.dll must be in the "\plugins\" folder. Path "plugins\userefi\" must exists. SMath Studio version: 0.89.8 (03 October 2010) |
It is working now  ancing: Thank you uni very much  BTW, I hope that something could be done in order the new user functions inserted via plugins could have their place under Insert|Function Category. At the moment they can be seen only in the "all" category and via Dynamic Assistance. Regards, Radovan Edited by user 23 November 2010 14:43:01(UTC)
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,472   Was thanked: 1735 time(s) in 587 post(s)
Now works for me too! Thank you uni!
Quote:At the moment they can be seen only in the "all" category and via Dynamic Assistance. Also they can be seen in the "Service\Plugins..." dialog, but remember that it's the test version. Mathcad strings are not supported yet and error tables too. |
Hello uni, uni wrote:Quote:At the moment they can be seen only in the "all" category and via Dynamic Assistance. Also they can be seen in the "Service\Plugins..." dialog, but remember that it's the test version. Ah yes, you are right- forgot to mention. I've looked there first to see how many functions the plugin consists of. Thank you for your efforts. I appreciate it very much. Regards, Radovan |
Hello uni,
now works on my system too! Thanks again for what you are doing. You are really a master , I am reading the russian forum ( bad traslated) and you are pushing forward costantly to improve the system with a lot of new ideas and results.
Keep on the good working and take care.
Francesco
Thank you, Francesco. Check new version on your system: mcadefi_20101124.7zThis one completely supports the User EFI interface, with strings and error messages. |
on 26/11/2010(UTC), on 26/11/2010(UTC)
Joined: 22/09/2009(UTC) Posts: 28  Location: Utah State University, Logan, UT, USA Was thanked: 6 time(s) in 4 post(s)
I have tried to load the Mathcad EFI plugins for SMath Studio 0.89(build 8) unsuccessfully. I copied the files "mcadefi.dll" and "mcaduser.dll", and the folder "userefi" (containing the files "bmqcad.dll", DIGAMMA.DLL", "KRONECKR.DLL", and "mathlib.dll"  into my SMath Studio directory, namely: "C:\Program Files(x86)\SMath\SMath Studio\plugins". I keep getting two messages indicating that it couldn't load or assembly "mcaduser.dll". I am using a Windows Vista Ulimate in a 64-bit Toshiba Satellite laptop. Any ideas on what I could be doing wrong? Gilberto Urroz
Try to put files (just mcaduser.dll and "userefi\*.*" ) on another path: "C:\Program Files\SMath\SMath Studio\plugins" P.S. I am afraid that for a 64-bit platform it will be necessary to recompile the project. Edited by user 29 November 2010 14:00:08(UTC)
Hmm... Uni could you explain why Avira Virus Lab detects file "bqmcad.dll" as Trojan??? I used online scaner as well: http://virscan.org/repor...d89b784c6534edfd326.htmlSo only 4 on 37 scanners detect it as something dangerous.  I'm almost sure that is OK but ... maybe you can put some light on it Uni. Edited by user 28 February 2011 23:54:06(UTC)
Joined: 03/10/2009(UTC) Posts: 4 Location: Copenhagen
have anyone had success with this plugin in Linux? The plugin is disabled and I'm getting an error report when starting SMath:
An exception was thrown by the type initializer for <Module>
And ideas?
/Lars
It uses an unmanaged code which probably isn't used in Mono. SMath Studio is completely written on .NET platform and Mathcad plugins aren't, mcadefi.dll - the intermediary between managed (.Net, SMath Studio) and unmanaged (Win32API, Mathcad UserEFI interface) code in Windows. Most likely in Linux it will never work. This plugin only for Windows (like Mathcad). Edited by user 29 March 2012 15:08:55(UTC)
I've noted that Mathcad EFI plugin has its own round(1) function. SMath has round(2). In spite of that the both functions have the same name but different numbers of arguments, when the EFI plugin is active then we can not use round(2). Here is a simple example:
EFI plufin enabled: cā80/9 c=8.8889 round(c)=9 round(c,3)=9
EFI plugin disabled: round(c,3)=8.889
Regards, Radovan |
This function from Mathematical library for MathCad v1.2 (Giuseppe Borzì ) which is in the userefi/mathlib.dll file. You can delete mathlib.dll and function round() will disappear without plug-in switch-off. The example with function is given in the Mathlib.pdf (page 3). |
