3 Pages<123
Offline kilele
#41 Posted : 20 May 2016 08:39:25(UTC)
kilele
Reselty, you can also use wsh sendkeys from mswindows without installing any external language, see if this works for you: https://helloacm.com/sen...ndow-using-sendkeys-wsh/
Offline reselty
#42 Posted : 23 May 2016 09:28:33(UTC)
reselty
Rank: Member
Switzerland
Hi Kilele
Sounds like you could read thoughts - This was/is the problem with FBSL... Couldnt find a portable version and tried allready some AutoIt and macrocreator/AutoHotkey.
I'll have a look on your suggestion - Thanks a lot!
Andreas
Offline kilele
#43 Posted : 23 May 2016 12:24:33(UTC)
kilele
Originally Posted by: reselty Go to Quoted Post
Hi Kilele
Andreas
Hi. You can compile .fbs to exe so you can run it on the final machine. Anyways, if you know autohotkey this script may be useful: http://www.donationcoder...oftware/Skrommel/#DoOver
Offline reselty
#44 Posted : 26 May 2016 15:01:53(UTC)
reselty
Rank: Member
Switzerland
Hi Kilele
I will test the DoOver way also, cause I did run a similar way with tinyTask, but there I couldn't define the speed (runs to fast) and edit the macro.
Thanks a lot!
Offline eltonsfg
#45 Posted : 19 November 2020 14:11:28(UTC)
eltonsfg
Hello guys!
I have a set of points x, y (speed and frequency) and I would like to take that moment of maximum speed, I have the corresponding frequency. Does anyone know to help me?
Example:
vector, x=[1 2 3 ...1000]
vextor, y=[100 300 400 ...100]
what point is in "y", "x" is max?
#46 Posted : 19 November 2020 16:48:32(UTC)
Your Y vector is incomplete. As it looks, it has different array dimension.
Nothing can be constructed from what you give.
Offline Razonar
#47 Posted : 19 November 2020 20:19:46(UTC)
Razonar
Uruguay
Hello guys!
Example:
Hi. This can be one solution.
FindingAbsMaximun.sm (10kb) downloaded 20 time(s).
or this other
FindingAbsMaximunEpsilon.sm (8kb) downloaded 16 time(s).
Edited by user 19 November 2020 20:40:13(UTC)  | Reason: Not specified
3 Pages<123
