This demo is constructed by parts. As it looks, only Mathcad 8/11 [other versions: don't know ?] supports the plotting convolviing argument in the X/Y plot. Jean Convolution RC Integration.sm (48kb) downloaded 78 time(s).
Thanks Davide,
Works well with the uninstalled 5346. The installed version does not have your "cases" from f(x) menu. 1/1 Mathcad, very elegant and neat.
Thank you for your examples Jean, hope to see even more in future (even from other users). Originally Posted by: Jean Giraud The installed version does not have your "cases" from f(x) menu. Probably "Custom Functions" plugin is missing in the new version. |
Originally Posted by: Davide Carpi Thank you for your examples Jean, hope to see even more in future (even from other users). Oh ! Davide, I have 100's model ... enough to "wear" Smath Cheers, Jean
Was thanked: 8 time(s) in 7 post(s)
I get: u - not defined SMath 5953
Basile
Basile ... Davide might help in there ! Jean
Apparently, there are a couple of hidden changes in the symbolic engine (both to investigate carefully ) - the first change involves the transit carrier (fixes in red boxes); - the second change involves the definition of a function using the function itself in the RHS (fixes in purple boxes; 99% s bug, the function is defined in the dynamic assistant but cannot be evaluated - "function is not defined" exception bug reported as SS-2335); FIX attached, works with both the versions (0.97 & 0.98) ConvolutionRC Integration [0.98.5953].sm (41kb) downloaded 49 time(s).Edited by user 03 May 2016 21:04:05(UTC)
Hello, The simplicity of the previous version has become complicated. but does not work. Any ideas? Basile Edited by user 07 May 2016 16:51:32(UTC)
same problem to me Win7 64 bit SMath 0.98 build 5953 Solved. Interference with plugin Maxima sergio Edited by user 19 May 2016 20:15:11(UTC)
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
It works for me. Win 10 64 bit SS 0.98 build 5953. |
Originally Posted by: Davide Carpi Apparently, there are a couple of hidden changes in the symbolic engine (both to investigate carefully ) - the first change involves the transit carrier (fixes in red boxes); - the second change involves the definition of a function using the function itself in the RHS (fixes in purple boxes; 99% s bug, the function is defined in the dynamic assistant but cannot be evaluated - "function is not defined" exception bug reported as SS-2335); FIX attached, works with both the versions (0.97 ========================================================= Ndtma, Sergio, Basile: the above explanation concerns your 5953. It may also suffer the same logical link bug as 5346 ... like this again. There are two versions of 5346: the installed version and the NON-installed versions. Both have substantial differences in what the plugin manager links or does not link wrt the f(x) menu. For instances: the installed version does link to the Matlab functions mwxxxxx, the UN-installed version DOES NOT link mwxxx Matlab library, but does link Davide plugin for module 'cases'. The installed 5346 DOES NOT link Davide plugin 'cases', does not link +++ stuff ... Levenberg-Marquardt just to cite one. All what I'm talking about is XP Home SP3. Something else to explore with other WIN OS. Read again and again what I wrote, up until the brain responds. I know what what I'm talking about, proof: Works/does not work is not enough for designers. Prove your assertion(s). Jean
