Was thanked: 8 time(s) in 7 post(s)
I try to solve some problems in AC electric circuits. Can I change the imaginary unit from i to j such that: I enter data using j, and output (from SMath) data using j?
Thanks, Basile
Joined: 17/01/2013(UTC) Posts: 296 Location: Khabarovsk, Russia Was thanked: 151 time(s) in 107 post(s)
Simple answer: no.
You may define a variable (j) or a unit ('j) equal to i, then you can use it to enter data. But you cannot get results using it (putting it to units placeholder won't give you much). Also you cannot use i as ordinary variable to hold arbitrary value afterwards, as this will ruin your j, too. |
Best regards, Mike Kaganski |
Thanks, Basile This the 'PJ" version [PJ = Pyjama] 1. Define imaginary user style 'j' 2. Don't re-use 'j' as index. 3. No need to spool to file, but X_Y plot does not take unit ° in "Angle" [Not defined]. I have removed previous posting and work sheets. Cheers, Jean Angle Data 'j'.sm (10kb) downloaded 18 time(s).
... just watch the unit system in your Engineering projects. Angle Data 'j'.sm (17kb) downloaded 11 time(s).
