  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,589   Was thanked: 1913 time(s) in 652 post(s)
SMath Studio 0.98.5952 available - Look and behavior of changing visible elements for output matrix significantly improved;
- Math Region performance improved in case of large expressions to be shown;
- SS-6: Region's error status cleared on description change for custom regions;
- SS-2312: Critical errors on pressing buttons from palette when cursor is in text entry inside the math equation;
- SS-2314: Function try(..) implemented;
- SS-2317: Font-size of the text in evaluable regions on file open fixed;
- Print page by page number issue fixed (happened after Print Preview shown);
- Multi-threading related issue fixed (rarely happened on file open);
- Refactoring.
Download Edited by user 18 April 2016 20:26:35(UTC)
| Reason: Not specified
 7 users thanked Andrey Ivashov for this useful post.
on 16/04/2016(UTC), on 16/04/2016(UTC), on 16/04/2016(UTC), on 16/04/2016(UTC), on 16/04/2016(UTC), on 16/04/2016(UTC), on 16/04/2016(UTC)
Joined: 17/01/2013(UTC) Posts: 296   Location: Khabarovsk, Russia Was thanked: 151 time(s) in 107 post(s)
I can create new descriptions, but cannot edit existing - it throws an exception.  |
Best regards, Mike Kaganski |
Thank you. Will check it today. I did good code review again, so some simple issues are possible. Edited by user 16 April 2016 14:50:33(UTC)
on 17/04/2016(UTC), on 18/04/2016(UTC)
No problem - that's what nightlies are for.
Other problem: error description (and lastError) seem to be in OS language, regardless of SMath UI language. E.g., in my Russian Win10, SMath UI is set to English, but for an erroneous block, I get error text "В экземпляре объекта не задана ссылка на объект.". |
Originally Posted by: mikekaganski  I get error text "В экземпляре объекта не задана ссылка на объект.". This is exception which is not handled correctly. That is why error is meaningless and not localized. Please explin how can I reproduce it.
Originally Posted by: Andrey Ivashov  Originally Posted by: mikekaganski  I get error text "В экземпляре объекта не задана ссылка на объект.". This is exception which is not handled correctly. That is why error is meaningless and not localized. Please explin how can I reproduce it. Page8.sm (2kb) downloaded 60 time(s). |
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,487   Location: Italy Was thanked: 1239 time(s) in 819 post(s)
Originally Posted by: mikekaganski  If I place the cursor in the rightmost placeholder and I press 2 times the "delete" key, I get an IndexOutOfRange exception;
System.IndexOutOfRangeException: Index was out of bounds of array. in SMath.Control.MathRegion.InsertManager(String value) in SMath.Control.MathRegion.OnCommandSend(String value) in SMath.Control.Worksheet.InsertManager(String value) in SMath.Control.Worksheet.Insert(String value) in SMath.Control.WorksheetControl.OnKeyPress(KeyPressEventArgs e) in SMath.Control.Worksheet.OnKeyPress(KeyPressEventArgs e) in System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m) in System.Windows.Forms.Control.WmKeyChar(Message& m) in System.Windows.Forms.Control.WndProc(Message& m) in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Edited by user 16 April 2016 18:52:30(UTC)
Joined: 23/07/2013(UTC) Posts: 760  Was thanked: 267 time(s) in 190 post(s)
Smath Studio 0.98.5950 creates "MathRegion.finish" error for several worksheets of mine and files couldn't be opened. Same files have no error at version 0.98.5932 and perfectly opened. I have uninstalled 5950 and installed 5932 with same plugins and there were no problems at all. As far as I witnessed I can open ".sm" files partially by disabling the plugins. The problems for my files are CheckboxList, ComboboxList, RadiobuttonList, WriterRegion plugins.
Originally Posted by: overlord  The problems for my files are CheckboxList, ComboboxList, RadiobuttonList, WriterRegion plugins. I've updated these 4 regions for this SS version (many thanks to Andrey for the help via skype); let me know if you notice other issues.  P.S. WriterRegion is relased as Beta, it contains also several minor fixes not related with this SS update and a new option to choose when to popup the toolbar (Options > Environment). If all it works fine I'll relase these things also for previous versions of SS. Edited by user 17 April 2016 03:27:05(UTC)
on 17/04/2016(UTC), on 17/04/2016(UTC)
thank you for quick return, now it seems all plugins work as they are supposed to be. Edited by user 17 April 2016 07:01:31(UTC)
I see that in 0.98.5951 the problems with descriptions and error string for my file had been addressed - thank you! Here is another file with the same error string - just assignment added. for-error.sm (2kb) downloaded 58 time(s). |
 1 user thanked mikekaganski for this useful post.
Originally Posted by: mikekaganski  Here is another file with the same error string - just assignment added. Thank you! Will fix it.
Initial 0.98.5950 build of this topic replaced with 0.98.5951 which contains several minor issues. All plug-ins revised and new versions of many of them were released, so, please update your plug-ins using Extensions Manager.
units-vanish-on-matrix-resize.sm (3kb) downloaded 55 time(s).If you try to resize a matrix, units in it disappear.  Edit: incorrect statement: units are converted to non-units (symbol "'" disappears from them). Also, copying matrices from/to a formula does the same. If you copy stand-alone matrix and paste it to a free space on sheet - it pasted OK. If you tried to paste to a placeholder in a formula, the following paste to a free space is with broken units (seems like clipboard is broken in that case). Edited by user 17 April 2016 19:51:59(UTC)
 2 users thanked mikekaganski for this useful post.
Originally Posted by: mikekaganski  If you try to resize a matrix, units in it disappear.  Thank you very much. Both issues (unhandled error and units disappearing) are fixed! Best regards. UPDATE: SMath Studio in the Cloud already has these fixes. Edited by user 17 April 2016 23:41:19(UTC)
on 17/04/2016(UTC), on 18/04/2016(UTC), on 18/04/2016(UTC)
"[" keyboard shortcut for el() behaves strange (doesn't add second placeholder?): when you type a matrix name (e.g. "a" ) and then type "[", then instead of subscript, this functional form appears: "el(a) " (without separator and placeholder). The same for nthroot() (Ctrl+\) Edited by user 18 April 2016 02:25:31(UTC)
Originally Posted by: mikekaganski  "[" keyboard shortcut for el() behaves strange (doesn't add second placeholder?): when you type a matrix name (e.g. "a" ) and then type "[", then instead of subscript, this functional form appears: "el(a) " (without separator and placeholder).
The same for nthroot() (Ctrl+\) Errors are fixed and new beta available. Please check. Thank you! Best regards. Edited by user 18 April 2016 20:24:05(UTC)
on 18/04/2016(UTC), on 18/04/2016(UTC), on 18/04/2016(UTC)
Sorry to be a nail in the ass, but now nthroot's keyboard shortcut (Ctrl+\) doesn't work.  Trying to copy a unit from some formula and pasting it into a unit (rightmost) placeholder of a result of some formula doesn't succeed. Newly added "try" element in tools panel hasn't tooltip. abs() is absent in Insert-Function... (Ctrl+E) dialog. Edited by user 19 April 2016 05:56:15(UTC)
