  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,589   Was thanked: 1913 time(s) in 652 post(s)
SMath Studio 0.98.5914 available - UnitsOf(..) function implemented;
- Function time(..) documented and updated to be visible in functions list;
- Function findrows(..) improved to work with numeric evaluations inside;
- Performance of Examples view load in Extensions Manager significantly improved;
- Displaying of error restored on region focus lost after right part of definition is not defined;
- Situations when parenthesis was hidden in answer fixed;
- Function trace(..) output switched to use standard delimiters instead of specific for user;
- Worksheet recalculation now starts on toggling of Disable/Enable evaluation context menu item;
- RichScrollbars style improved for systems with disabled system style;
- Text in search box now selected when panel visibility toggled on;
- Ability to print worksheet using command prompt implemented (-silent -p default worksheet.sm);
- Command prompt interface extended to allow worksheet testing (-silent -t worksheet.sm);
- Numeric library improved to avoid displaying unnecessary "1" in expressions like "1*'unit";
- Interface translations updated.
Download Edited by user 15 March 2016 19:26:09(UTC)
| Reason: Not specified
 8 users thanked Andrey Ivashov for this useful post.
on 12/03/2016(UTC), on 12/03/2016(UTC), on 12/03/2016(UTC), on 12/03/2016(UTC), on 12/03/2016(UTC), on 12/03/2016(UTC), on 12/03/2016(UTC), on 12/03/2016(UTC)
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,487   Location: Italy Was thanked: 1239 time(s) in 819 post(s)
Hello Andrey, I see there is at least another command prompt feature available (SS 0.96.4902) Quote:Added ability to export files to supported formats using command prompt; What's is syntax? There are other of these commands?  Edited by user 13 March 2016 11:40:33(UTC)
Help command is: Code:SMathStudio_Desktop.exe -silent -?
Thank you very much Andrey! It is very useful for batch processing! Documented in the wiki and linked in the wiki main page. Not sure which options are available with -o or how to change the printer (some attempts I've done they results always with the default printer) |
Joined: 25/09/2013(UTC) Posts: 314  Location: IL Was thanked: 18 time(s) in 16 post(s)
Does this mean I can print multiple files to PDF in with some sort of single command?
Hello. Thank you for good questions! Originally Posted by: Davide Carpi  Not sure which options are available with -o It may be anything. F.e. you can create a File Type plug-in and implement the following method: Code:bool IPluginSaveFileTypes.SaveFileType(Stream stream, RegionsEnumerator enumerator, FileContext context)
To get options from -o in this plug-in you can read context.Action. So, this is how one can perform files conversion with some options (of course plug-in should support this). Originally Posted by: Davide Carpi  how to change the printer (some attempts I've done they results always with the default printer) For now selecting exact printer name is not supported. Default is an only option. Sorry  Will be implemented in future. Originally Posted by: RFreund  Does this mean I can print multiple files to PDF in with some sort of single command? Yes. F.e. here is a *.bat file content which converts all files in folder from .sm to .png: Code:@echo off
for %%a in ("C:\examples\*") do call:convert %%a
exit/b
:convert
call "C:\Program Files (x86)\SMath Studio\SMathStudio_Desktop.exe" -silent -e .png %*
BTW: -t parameter is actually a way similar to what I use to be sure nothing broken before releasing a new build. I have hundreds of worksheets which passed to SMath Studio in order to ensure that calculation results saved in those files are not changed after recalculation by new version of the program. One can use it also to quickly check that important files are still works after update. If not - contact me, so I could do fix asap. Best regards.
on 13/03/2016(UTC), on 13/03/2016(UTC), on 19/03/2016(UTC)
Sorry for the delay, Thanks Andrey!
