Hi. The default language is russian. How to change it to another language ?
anis wrote:Hi. The default language is Russian. How to change it to another language ? Hello. Hmm. First time SMath Studio starts it chooses the interface language according to your Operating System settings. So, it's a little bit strange... But, if it happens, than use following screens: This screens are from new beta-version and if you use old 0.50.0-0.50.4 version I advise you to install the latest here.
Hello, I had this problem, too. I just deleted all other (not wanted) language files in smath directory "lang". That works fine, too. Possible a easy method to write in a readme for distribution files ?
I'm just starting to work with this program, but it looks great. Until now I'm not sure how to work with it. I try to store some first samples in your forum if I solve it.
In case developers are reading this forum, I ran into the same issue, and was able to fix thanks to your guide. FYI: I'm using HTC Touch Diamond (Windows Mobile 6.1 Professional) with the locale and language set to Slovak. When I first launched SMath (version 0.78 build 3347) it was set to Bulgarian - possibly because SMath doesn't support Slovak. I think the default in these cases should be English. Also, it appears to run a little slow on my device, but otherwise it is a fantastic calculator - I installed it mainly from nostalgia, to remember my university times. But that was a completely different age - I didn't even have a mobile phone then...
Thanks for the information. I didn't knew that so many people has the same issue... will check/fix the default language then. Edited by user 11 March 2009 04:31:04(UTC)
| Reason: Not specified
That's it. Problem was localized and fixed. Next version will set English as the default language (in case, when yours system language is not available as interface lang).
smath wrote:That's it. Problem was localized and fixed. Next version will set English as the default language (in case, when yours system language is not available as interface lang). Cool, thanks for a quick fix!
