Offline Andrey Ivashov
#1 Posted : 11 October 2010 20:44:35(UTC)
Hello. Cannot reproduce this. For me it looks OK.
Regards.
Offline oscampo
#2 Posted : 11 October 2010 20:50:15(UTC)
oscampo
Colombia
Was thanked: 85 time(s) in 65 post(s)
SMath can find a "symbolic" soluction for yor equation using "Ctrl+." :
a:1
b:2
c:3
d:4
F(x)←(a+b*(x/V)+c*(x/V)^2+d*(x/V)^{-2})
don't use "=" for asking for F(100*V)
use "Ctrl+." instead:
F(100*V)—75502501/2500
Then copy the "symbolic" answer and use "=" to find:
75502501/2500=3.02*10^4
Oscar Campo
Offline oscampo
#3 Posted : 11 October 2010 20:52:19(UTC)
oscampo
Colombia
Regards.
You are using "V" as a unit, But that the original post says that "V" is a constant.
Offline omorr
#4 Posted : 12 October 2010 23:46:50(UTC)
omorr
Serbia
Hello asdfghjkl
I do not quite understand you, sorry. I would suggest you to use SMath and math tags - not the text:
For instance,
Instead of using:
a+b(x/V)+c(x/V)^2
Use this, by math tags and copying from SMath - like this:
a+b*(x/V)+c*(x/V)^2
(see the Wiki pages and Notes of how to use the Forum, please).
However, I would try to be a "mind reader" regarding your question.
In the previous posts, there was the advice to avoid using units in some complicated functions - errors are easy to make.
Now, you tried to use integration with the functions and variables having units. Let's try it. First of all, you should know that SMath does not do the symbolic integration - only numeric. Moreover, I think it does not work well with units.
Here is an example, similar to your request (I hope):
Function F(x) might represent a specific heat function receiving "x" in unit temperature (Kelvin) and returning the result in unit (BTU/(mol*K)). Now, you will try to calculate enthalpy "Y" by integrating specific heat over a temperature range (say from 300 to 800). It worked, but it is a bit confusing because we forced the integration to use units - the result should be in (BTU/mol).
For comparison here is the same calculation performed in Mathcad
To repeat the advice from my own experience - try to avoid units for complicated calulations. Units are quite safe and useful to use when you have the basic algebraic operation - addition, substraction, multiplication, division and raise to power.
Edited by user 13 October 2010 12:40:21(UTC)  | Reason: Not specified
Similar Topics
using some math functions with units (log) (Questions)
by harry bee Yesterday at 02:17:52(UTC)
Inconsistent function behavior (Bugs & Problems)
by Luhkoh 13/04/2024 02:56:05(UTC)
Reverse breaks vectorize function (Questions)
by Douwe 09/04/2024 00:04:23(UTC)
Functions for Permutation and combination (Questions)
by netsonicyxf 27/03/2024 17:47:48(UTC)
Vidalista Black 80 Mg Is The Best Popular Pill For Erectile Dysfunction (Features announcements)
by eliadavised 21/02/2024 23:00:18(UTC)
Fildena 150 Tablet Treat Erectile Dysfunction Problem (Questions)
by Sophia Jones 09/01/2024 00:01:08(UTC)
Average If function (Questions)
by gth802s 28/12/2023 09:55:01(UTC)
GorillaFlow: Embrace Prostate Health and Enjoy Improved Urinary Function (Questions)
by Guest 01/12/2023 03:08:19(UTC)
3D Plot function help request (Questions)
by Ale_Biaso 29/11/2023 13:02:54(UTC)
Solving Symbolic Function (Questions)
by Jonah 22/11/2023 23:37:30(UTC)
"Cases" function and for loop (Questions)
by gth802s 21/11/2023 06:06:52(UTC)
Newbie question: why this picewise function not plot? (Questions)
by kaizh 13/11/2023 21:13:03(UTC)
2D plot, parametric functions (Bugs & Problems)
by overlord 12/10/2023 03:51:06(UTC)
Help with Graph Function (Questions)
by Igor_Mag 05/10/2023 19:27:35(UTC)
Cases function new case (Questions)
by cedreine 04/10/2023 22:29:22(UTC)
