Is there an edit command to transpose a matrix/vector? Not a computed transpose but an edit. eg I have
a={1,2,3}
I press the edit-transpose key and change the data to
.....{1} a={2} .....{3}
Sorry, I did not quite understand the question. Just a suggestion. Could you use [BB/] and [MATH] tag. Just copy from SMath and paste into it. If you like, you can also put the screenshots on the Wiki and make a link to those pictures by "Insert image" tag. It might be more understandable.
Regards, Radovan
Joined: 30/08/2009(UTC) Posts: 52 Location: Australia
I don't think there is an edit command for transpose, but there is a transpose operator in the matrix toolbox
so after you've entered a, type a:a and then click the transpose operator (T)
