Joined: 22/10/2009(UTC) Posts: 53 Location: Gedongkuning, Jogjakarta Was thanked: 1 time(s) in 1 post(s)
When I save sm as htm and see the source, the order of png images is very strange,starting the last number on top and the lowest number (...._0.png) at the bottom. ... ..._2.png ..._1.png ..._0.png
It creates a problem when I convert into Latex using html2latex, the order will be following the list written in htm file, not considering the position absolute.
Is that possible I can get the order ....._0.png ....._1.png ....._2.png ...
Thanks and regards waluyo
Will check later today... and fix Thanks.
