Offline Ber7
#1 Posted : 31 August 2014 16:02:06(UTC)
Ber7
Israel
Was thanked: 520 time(s) in 288 post(s)
Animation of mechanisms with two or more degrees of freedom by A.B. Ivanov
Explanatory example.
The mechanism comprises a crank, of two connecting rods and slide,
is driven by a crank. Find all the provisions of the mechanism
for one complete revolution of the crank.
We will use the proposed AB Ivanov method which
is as follows.
We choose from six coordinates defining the position of the mechanism,
two, for example one of the coordinates of the end of the crank (x1) and the coordinate
slider (x6) .To transfer mechanism links from the position that
it takes at time t and which corresponds to the values
two coordinates x1, x6, infinitely close to the position he
holds at time t + dt, and which corresponds to the coordinates
x1 + dx1, x6 + dx6, you can proceed as follows.
At first we fix the coordinate x1, ie. to the four equations
geometrical constraints add the fifth equation x1 = 0, and move the
slider on the value dx6.
Then 6x increase, and x1 does not change.
Then move the end of the crank on the value of dx1, and fix the slide ,
fifth equation will now x6 = 0.
Repeat this procedure until, until we find all the provisions of the mechanism. .
Note that since the two coordinates of the six chosen arbitrarily
and optionally set the order of their alternation, there is
a plurality of solutions, of which two are presented in animations.
Planar three-link manipulator1
Planar three-link manipulator2
Edited by user 30 September 2014 17:11:37(UTC)  | Reason: Not specified
File Attachment(s):
Primer.pdf (158kb) downloaded 142 time(s).
3LinkPlos.smz (8kb) downloaded 90 time(s).
2RC-2polsuna.smz (9kb) downloaded 72 time(s).
Primer.smz (10kb) downloaded 85 time(s).
thanks 1 user thanked Ber7 for this useful post.
on 31/08/2014(UTC)
Offline Ber7
#2 Posted : 31 August 2014 16:10:23(UTC)
Ber7
Israel
Robot Manipulator
TS serial chain.
Edited by user 08 October 2015 21:44:59(UTC)  | Reason: Not specified
File Attachment(s):
Puma Ploskaya.smz (64kb) downloaded 45 time(s).
TS serial.smz (67kb) downloaded 64 time(s).
1 stepen'.smz (78kb) downloaded 61 time(s).
on 31/08/2014(UTC)
Offline Ber7
#3 Posted : 31 August 2014 16:16:41(UTC)
Ber7
Israel
Puma_Sphera 1.smz (71kb) downloaded 33 time(s).CS serial chain
Puma1
Edited by user 23 April 2016 10:37:48(UTC)  | Reason: Not specified
File Attachment(s):
Puma_Sphera 1.smz (65kb) downloaded 51 time(s).
CS serial.smz (44kb) downloaded 71 time(s).
on 31/08/2014(UTC)
Offline Ber7
#4 Posted : 31 August 2014 21:11:35(UTC)
Ber7
Israel
Puma
Edited by user 09 November 2014 14:53:09(UTC)  | Reason: Not specified
File Attachment(s):
Puma.smz (65kb) downloaded 67 time(s).
on 19/02/2015(UTC)
Offline Ber7
#5 Posted : 19 February 2015 01:10:24(UTC)
Ber7
Israel
Center triangular platform planar manipulator (shows two designs)
moves along a predetermined path rectangular.
For animation   was used the procedure A. B. Ivanov,
animations mechanisms with several degrees of freedom.
File Attachment(s):
RRR4.smz (11kb) downloaded 61 time(s).
RPRrestangle.smz (10kb) downloaded 57 time(s).
on 19/02/2015(UTC)
Offline алексей_алексей
#6 Posted : 06 April 2015 10:40:53(UTC)
алексей_алексей
Was thanked: 13 time(s) in 8 post(s)
