Offline marks2c
#1 Posted : 07 January 2023 01:08:49(UTC)
marks2c
New Zealand
Was thanked: 4 time(s) in 3 post(s)
This matrix generator (thanks gUrrozEN) produces random 'equal-probability' values for a given center value and tolerance band.
I'm hoping to revise this to return values within a normal/Gaussian probability as illustrated:
Random to Normal.sm (43kb) downloaded 3 time(s).
Any thoughts?
Edited by user 07 January 2023 03:37:44(UTC)  | Reason: Not specified
#2 Posted : 07 January 2023 04:47:00(UTC)
Originally Posted by: marks2c Go to Quoted Post
Any thoughts ?
Native Smath plugins generate uniform randoms.
The Central Theorem proves that enough uniform randoms
generate a Normal Distribution.
You simply need to bin in an histogram utility.
Is that is what you are looking for ?
Otherwise, I don't understand your request.
Offline marks2c
#3 Posted : 07 January 2023 08:07:39(UTC)
marks2c
New Zealand
Thank you for the reply Jean.
I'm after a method or function that will return a random value with the probability that 68.2% of the time it will be within 1 sigma, and 95.4% of the time it will be within 2 sigmas, etc.
Edited by user 07 January 2023 11:35:10(UTC)  | Reason: Not specified
Offline Razonar
#4 Posted : 07 January 2023 10:13:06(UTC)
Razonar
Uruguay
Hi. For 'convert' random uniform distributed numbers between 0 and 1 to another probability distribution, in your case, for get some normal distributed numbers you can use the inverses of the cdf distributions. You can check that here for 1000 numbers you have the desired mean and std deviation
so, I guess that in your function rmat this is the function for normal distributed numbers
random to nomral.sm (6kb) downloaded 8 time(s).
on 07/01/2023(UTC)
Offline marks2c
#5 Posted : 07 January 2023 11:32:57(UTC)
marks2c
New Zealand
Thanks Alvaro, very greatly appreciated.
For me, the sample file has a problem:
Offline Razonar
#6 Posted : 07 January 2023 11:55:38(UTC)
Razonar
Uruguay
Hi. I mean: substitute that M[i,j] into your rmat(...) function for get normal distributed numbers with the rmat algorithm instad uniform distributed ones.
on 07/01/2023(UTC)
#7 Posted : 07 January 2023 17:22:38(UTC)
I don't understand completely ... sorry.
However, from a native random sigma, you can solve for a desired other one.
Cheers, be good Down Under ... Jean.
Random NORMAL Histogram Copy.sm (45kb) downloaded 3 time(s).
Offline marks2c
#8 Posted : 07 January 2023 21:44:13(UTC)
marks2c
New Zealand
Thank you both. Alvaro: perfect, thank you.
Here is the working update:
20230109 Random to Normal.sm (55kb) downloaded 8 time(s).
Edited by user 09 January 2023 06:48:25(UTC)  | Reason: Updated with the finished item.
Offline marks2c
#9 Posted : 09 January 2023 07:41:49(UTC)
marks2c
New Zealand
See the updated post above.
#10 Posted : 09 January 2023 18:44:09(UTC)
20230109 Random to Normal_1.sm (82kb) downloaded 7 time(s).
