SMath Studio Forum
Questions
Normal/Gaussian Function or Method: Normal Probability Density
Joined: 01/04/2020(UTC) Posts: 85 Location: Wellington Was thanked: 4 time(s) in 3 post(s)
This matrix generator (thanks gUrrozEN) produces random 'equal-probability' values for a given center value and tolerance band. I'm hoping to revise this to return values within a normal/Gaussian probability as illustrated: Random to Normal.sm (43kb) downloaded 3 time(s).Any thoughts? Edited by user 07 January 2023 03:37:44(UTC)
| Reason: Not specified
Originally Posted by: marks2c Any thoughts ? Native Smath plugins generate uniform randoms. The Central Theorem proves that enough uniform randoms generate a Normal Distribution. You simply need to bin in an histogram utility. Is that is what you are looking for ? Otherwise, I don't understand your request. Cheers ... Jean.
Thank you for the reply Jean. I'm after a method or function that will return a random value with the probability that 68.2% of the time it will be within 1 sigma, and 95.4% of the time it will be within 2 sigmas, etc. Edited by user 07 January 2023 11:35:10(UTC)
Hi. For 'convert' random uniform distributed numbers between 0 and 1 to another probability distribution, in your case, for get some normal distributed numbers you can use the inverses of the cdf distributions. You can check that here for 1000 numbers you have the desired mean and std deviation so, I guess that in your function rmat this is the function for normal distributed numbers random to nomral.sm (6kb) downloaded 8 time(s).Best regards. Alvaro.
Thanks Alvaro, very greatly appreciated. For me, the sample file has a problem:
Hi. I mean: substitute that M[i,j] into your rmat(...) function for get normal distributed numbers with the rmat algorithm instad uniform distributed ones.
Originally Posted by: marks2c Thank you for the reply Jean.
I'm after a method or function that will return a random value with the probability that 68.2% of the time it will be within 1 sigma, and 95.4% of the time it will be within 2 sigmas, etc. I don't understand completely ... sorry. However, from a native random sigma, you can solve for a desired other one. Cheers, be good Down Under ... Jean. Random NORMAL Histogram Copy.sm (45kb) downloaded 3 time(s).
Thank you both. Alvaro: perfect, thank you. Here is the working update: 20230109 Random to Normal.sm (55kb) downloaded 8 time(s).Edited by user 09 January 2023 06:48:25(UTC)
| Reason: Updated with the finished item.
See the updated post above.
SMath Studio Forum
Questions
