Offline coeur_de_lion
#1 Posted : 27 November 2022 19:04:29(UTC)
coeur_de_lion
Rank: Member
Is it possible to import a results from another smath studio file and then use it as a imput for the second file?
Thanks
Offline overlord
#2 Posted : 27 November 2022 19:34:59(UTC)
Turkey
Use include() function.
Learn more from Reference Book.
Offline overlord
#3 Posted : 28 November 2022 20:13:30(UTC)
Turkey
To be ensure new users not getting confused by Jean's immorally promoted and irrelevant samples;
Question was calculating and getting result from another worksheet.
Not writing results into file getting them in same sheet.
Here is an example how include() can be used.
include_main.sm (4kb) downloaded 15 time(s).
include_sub.sm (3kb) downloaded 13 time(s).
thanks 2 users thanked overlord for this useful post.
on 28/11/2022(UTC),  on 28/11/2022(UTC)
#4 Posted : 28 November 2022 23:25:02(UTC)
coeur_de_lion
Rank: Member
Hello guys!
Thank for the support.
Bye
#5 Posted : 29 November 2022 00:56:54(UTC)
Originally Posted by: coeur_de_lion Go to Quoted Post
Is it possible to import a results from another Smath Studio file and then use it as a input for the second file?
You can try from the attached.
As given, re-code the the referenced include(,)
Should work as they will be from the same download directory.
Genfit Minimize Include Test.sm (59kb) downloaded 8 time(s).
Genfit Minimize Include.sm (32kb) downloaded 7 time(s).
Include(,) is more for advanced maths
#6 Posted : 29 November 2022 02:19:57(UTC)
Answer is YES ... from various results.
... imported from SmathFile into main Directory.
Offline mkraska
#7 Posted : 29 November 2022 11:42:06(UTC)
mkraska
SMath studio has the built-in functions rfile() and wfile() which are used to store and retrieve expressions to/from the file system.
These native functions don't provide control as to where the files are stored (if I recall correctly, it is the settings directory (install directory if using a portable version).
Yet the Mathcad toolbox plugin provides extended functions with path control, e.g. you can enforce storage at the document directory.
wfile.sm (4kb) downloaded 8 time(s).
Offline overlord
#8 Posted : 29 November 2022 17:04:26(UTC)
Turkey
Jean, stop messing people's topics.
Post this not-related replies to samples.
