Hi, I am trying to setup a table from extracted data from a matrix, but when I create the table I cant add the left stub, the image below shows 4 tables: table 1 uses ls as the main body and I can add ζ.in as the right stub table 2 use CSA.in as the main body and allows ls to be added as the left stub table 3 the same as table 2 but using ζ.in as the main body table 4 is the issue, here I can add the main body/header, but will not allow the addition of the left stub. All 3 data sets appear to be the same, where have I gone wrong, or is there a bug? sheet attached: Table errors.sm (33kb) downloaded 4 time(s).
I don't think it's a bug. It happens for how you built the TB matrix. If you use "Augment" it works well. Table_errors_s.sm (35kb) downloaded 26 time(s).sergio
Hi Sergio,
Brilliant & thanks, I didn't know you could do that for tables. This will help for future work as well. Ian
