Originally Posted by: Prmtv Hello. Given matrix. Using combobox selector and radiobutton selector I get the required data. Everything is working inside program, but don't working in Viewer.
I understand what the problem is. It's a feature plugin RadioButton. For correct display in SMath Viewer, it must be used first among others plugins from "Controls". If it is not used first or used two in a row, it will display incorrectly in SmathViewer. In my example, two RadioButton in a row are used. It is strange that everything works well in the program itself, the problems are only when using SmathViewer
