Joined: 04/07/2015(UTC) Posts: 6,866  Was thanked: 983 time(s) in 811 post(s)
Confirmed: works fine SS 6179
Originally Posted by: avp  What does this mean for me as a Smath user ? Simoly: hope some user of your SS version will catch/isolate the bug.
Joined: 28/08/2014(UTC) Posts: 1,533  Was thanked: 989 time(s) in 618 post(s)
Originally Posted by: avp  ... Thank you. But the problem is not because of eval(). She's somewhere deeper. My f3(x) and f4(x) limits are ainterp() of the table data. Hi avp. Try using eval() for ainterp().  Best regards. Alvaro.
The type errors your version reports is wrt some limit(s) of the double integration. Why specific to this version ?
Originally Posted by: Jean Giraud  The type errors your version reports is wrt some limit(s) of the double integration. Why specific to this version ?
I dont know. I wanted to know here why the calculation of integrals, which used to work well before, broke down after adding the ability to use the dimensions of units in integrals.
Originally Posted by: avp  I don't know. I wanted to know here why the calculation of integrals, which used to work well before, broke down after adding the ability to use the dimensions of units in integrals. You have a good point about units in integral. Attached is your saved working version. Open in your latest SS. It may rescue the integrator. God save the Queen and avp.
Cheers ... Jean. Integrate Double Didactic Russia.sm (73kb) downloaded 26 time(s).
Originally Posted by: Razonar  Workarounds for the integration bug. Hi, Alvaro. The result is not correct. The result should be Kx = 1.233, Ky = 1.044
Originally Posted by: avp  The result is not correct. The result should be Kx = 1.233, Ky = 1.044 ... those values are same in my document. You didn't report working/crap ?
Originally Posted by: avp  Hi, Alvaro. The result is not correct. The result should be Kx = 1.233, Ky = 1.044
Hi avp. I hope the problems with double integrals can be solved, because the calculation of double integrals that SMath had was quite powerful. The only way to calculate Kx, Ky would be to discretize and integrate over the cubic splines curve. Proizvol'noe sechenie_no XLSX.sm (78kb) downloaded 13 time(s). Proizvol'noe sechenie_no XLSX.pdf (288kb) downloaded 12 time(s).Best regards. Alvaro. Edited by user 09 July 2022 02:00:47(UTC)
| Reason: Not specified
This document is adapted/doctored in native Smath 6179. It does not scratch Smath a bit. As you download, after it has finished it offers to update: click close to be back SS 6179.Re=download and let it update latest SS. If you have red as it complained, probably the integrator is freaked in that version ... hard to explain. Cheers ... Jean. Integrate Double Didactic Russia (3).sm (75kb) downloaded 10 time(s).
... code that test double integration in your latest SS. Hoping more Collab will code as well to sanity.
